Viz Plug-ins User Guide
3D Line Shader
The 3D Line Shader plug-in is used by the 3D Map Setting plug-in to draw the borders using the parameters set in the various 2D Label plug-ins. It is added automatically when adding a 2D Label object to the scene tree.
Note: This plug-in is located in: Plugins -> Shader plug-ins -> Maps
3D Line Shader Properties
This plug-in has no editable parameters.
