Viz Plug-ins User Guide
N Quad
The N Quad plug-in creates a rectangle with different attributes.
Note: This plug-in is located in: Plugins -> Geom plug-ins -> Primitives
N Quad Properties
Use LOD: Enables/disables dynamic level of detail.
Tessellation U: Sets the degree of detail.
Tessellation V: Sets the degree of detail.
Orientation: Switches the orientation from Top Bottom to Left Right.
Top/Left Width: Sets the width.
Bottom/Right Width: Sets the width.
Height/Width: Sets the height.
Depth: Sets the depth.
Center X: Switches the center in X between Center, Top and Bottom.
Center Y: Switches the center in Y between Center, Left and Right.
Shearing: Sets the shearing value, so the bottom is shifted.
Image Mapping: May be set to Stretch or Tile.
Crop Top/Left: Crops the top.
Crop Bottom/Right: Crops the bottom.
Border Geometry: Enables/disables the top and bottom border width parameters. When enabled, only the border outline is visible.
Top Border Width: Sets the width of the top border.
Bottom Border Width: Sets the width of the bottom border.
To Create an N Quad
Create a new group and add the N Quad plug-in to it.
Add a material and/or a texture to the group.
Open the transformation editor and set Rotation X and Z to -45.0.
Open the N Quad editor and set the following parameters:
Set Orientation to Left-Right.
Set Top/Left Width to 200.0.
Set Bottom/Right Width to 0.0.
Set Height/Width to 300.0.
Set Depth to 100.0.
Set Center X and Y to Center and Bottom, respectively.
