Viz Plug-ins User Guide
Hide On Empty
The Hide On Empty plug-in hides its container when a target text geometry matches a given condition. The condition may be an empty text, or text displaying a zero value, such as 0 or 0.0, depending on the plug-in parameters.
Hide On Empty Properties
Text container: Specifies the container of text of which to check the content.
Self: The text geometry is in the same container as the plug-in is applied to.
First child: The text geometry is in the first child container of the container the plug-in is applied to.
Other: Enables the Other text container drop area.
Other text container: Drag the container containing the text geometry to set the target. Enable by selecting Other as Text container.
Treat as numerical: Hides the target container if the specified text is 0 or 0.0, in addition to empty text.
Invert visibility: Displays the container when the condition is satisfied instead of hiding the target container when the condition matches.
Update Geometry: Updates the visibility state of the container holding the plug-in after changes, removal, or assignment of target text geometry, during the design process.
Note: You cannot use the control plug-in Control Hide on Empty in conjunction with Control Text using the same field identifier. In such a case, use the Hide On Empty property in the TextBG plug-in.
