Viz Plug-ins User Guide
Text FX Scale
images/download/thumbnails/95402176/ico_tfx_scale.png
The Text FX Scale plug-in allows you to create a scaling animation of the characters.
Supported Pipelines
Classic Render Pipeline
images/s/2wwyjx/8804/1yuue1v/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
Text FX Scale Properties
  • Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
  • Anchor Vertical: Sets the anchor point for the characters on the vertical plane.
  • Use Axis: Defines on which axis or axes the characters scale.
  • Lock Axis: Scales the Begin- and End the same for all the axes when enabled. If you disable the parameter, Begin and End must be set for all the axes individually.
  • Begin: Sets the initial size of the characters.
  • End: Sets the ending size of the characters.
