Version 5.6 | Published July 22, 2024 ©
Template Device Functions
This section lists a selection of device properties:
Working with Device Functions
Right-click inside the device function area to open a menu containing the following options:
Enable: These commands are described in more detail below.
Template properties: Opens the current template's properties page, see Template Properties in section Working with Templates.
Clear devices: Removes all devices from the device function menu, after confirming in a pop-up message window.
Apply device settings to all sets: Applies all the device settings to all templates of same type and variant throughout all template sets.
To Enable Device Functions
Right-click in the device's Function area (black row).
Select the device to configure from the Enable menu.
This opens the edit box for the selected device.
        Note: Depending on the protocol chosen, the caption EMEM Recall may alternatively be:
Emem Recall
Dmem Recall
Snapshot Recall
Memory Recall
To Modify Device Functions
Select Device properties. See the topics below for listings of properties for each device.
Note: Depending on the Protocol chosen, the caption Macro Recall may alternatively be:
Custom Control
To Remove Device Functions
Right click in the Device function area
De-select it from the Enable menu.
Linking Device Properties and Newsroom Tags
To Make a Device Property Editable from the NRCS
Right-click over Property and select Add newsroom tag.
The property is then reassigned to the value supplied from the newsroom system.
If several device properties are given to a newsroom tag with the same name in a template, all devices use the value given in the NRCS.
See also: Newsroom Tags.
Testing a Template
You can test the behavior of your template by simulating a Preview (cue) followed by a Take.
To Test a Template
Press the Take button to the right of the template heading.
This cues the template in Preview, and then five seconds later takes it to Program with the selected transition.
Video Switcher Crosspoint
The video switcher crosspoint enables switching on the video switcher. The A or B bus assignment of the mixer effect (PP/MEx) is automatically handled by the automation.
Guidelines for Video Switcher Crosspoint Configuration
         Item  |
         Description  |
         Mix Effect  |
         Selects which Mix Effect (ME) bank on your vision mixer that you are currently handling.       |
         Crosspoint  |
         Crosspoint on the video switcher. Default value: none
         Audio link  |
         Default value: none       |
         Crosspoint PP  |
         If another Mix Effect (ME) than PP is selected, then you can select a crosspoint for program by writing the crosspoint name in the field.  |
         Set ME in PP  |
         If another Mix Effect (ME) than PP is selected, check this box to make that ME the crosspoint for PP. (Checking this box disables XPOINT PP).  |
         Cross Point Hold  |
         Keeps the crosspoint on the selected Mix Effect.  |
         Mix Delay  |
         Offset, in frames, of when to perform the transition.  |
         Mix Delay Out  |
         Delay, in frames, of when to perform the next transition.  |
         Transition Only  |
         Only delay the switcher transition (sub items will perform).  |
         DSK Off  |
         Turns off the Downstream Keyer (DSK) on the video switcher when the template is active in program.       |
         DSK 2 On, ...,  |
         Downstream Keyer (DSK) 2-8 on. Turns on the DSK 2-8 (PP key 2-8) on the video switcher when the template is active in program.       |
         Off delay  |
         Delay in frames to set the DSK 2-8 off.  |
Video Switcher Transition
The transition device is only available when video Switcher crosspoint is enabled.
To Define Video Switcher Transitions
This procedure is based on the example in the screenshot.
Click on MIX/WIPE/EFFECT to cycle through these three transition types.
Click directly on the selected value (in the screenshot above, this is either 0 or 1).
Enter
The default duration (in frames) for the Mix/Wipe transition, or
The effect number for the effect transition.
The transition is performed with the auto-transition functionality in the video switcher.
Usage and Tips
To do a cut, use a MIX transition with 0 frames duration.
To add a mix delay, right-click on the device ( MIX/WIPE/EFFECT ), select the number (below Disable), and enter another number (in frames) .
Adding a mix delay delays the start of the transition, compared to other device commands, when the template goes On Air. -
To disable the transition, right-click over the device and select Disable.
Video Switcher Register/Timeline Recall
Video Switcher Register/Timeline Recall (EMEM Recall/Emem Recall/Dmem Recall/Snapshot Recall/Memory Recall) will recall a register and/or timeline in the video switcher.
To Open the Video Switcher Register/Timeline Recall
Open Template Editor.
Right-click over ememnr_pr
Select Enable > EMEM Recall
Enter or select required values
Note: If a Register recall is paired with the video switcher key bus delegation and/or auxiliary bus delegation, the key/aux bus delegation should be disabled in the Video Switcher Register to prevent a conflict between the stored delegation and the Viz Mosart-assigned delegation.
Guidelines for Video Switcher Register/Timeline Recall Configuration
         Item  |
         Description  |
         NAME  |
         Name of Register/Timeline.  |
         DESCRIPTION  |
         Description of Register/Timeline.  |
         MIXEFFECT  |
         Select the MIXEFFECT (ME) from where the Register/Timeline should be recalled. Drop-down menu values are PP (Program), ME1, ME2, ME3, ME4, and Master. Default value: Master. To dynamically choose ME1 or ME2, values M_RIP and M_OTH are available. Note: Newsroom tag available  |
         EMEMNR PREVIEW  |
         Register/Timeline on the video switcher that will be recalled when the template is cued in Preview.  |
         EMEMNR PROGRAM  |
         Register/Timeline on the video switcher that will be recalled when the template is taken to Program.  |
         LOAD TIME  |
         Delay time (in frames) between when the mixer register is recalled (in Program or Preview) and when all other template instructions are executed.  |
         OPEN VS FADER  |
         When selected, Viz Mosart opens the fader specified in Audio effect server, defined in the Audio tab of Device Properties in AV Automation.  |
Macro Recall
Macro Recall is available when the following vision mixer protocols (as selected in the configuration menu Vision Mixer):
Ross Acuity
Ross Carbonite
GV CPL
GV KAHUNA (Kahuna/Kula)
SONY SERIAL TALLY
VIZRT-IPS (NewTek/Vizrt Group IP series mixers (for example, Viz Vectar Plus, TriCaster, VMC1).
To Open a Macro Recall
Navigate to Enable > Macro Recall
Enter or select required values.
Guidelines for Macro Recall Configuration
         Item  |
         General description  |
         Drop-down  |
         Text field  |
         Recall preview  |
         Action to be taken when entering preview mode.  |
         See below  |
         See below  |
         Recall program  |
         Action to be taken when entering program mode.  |
         See below  |
         See below  |
Drop-down Menu Alternatives
         Drop-down option  |
         Description  |
         None  |
         No action.  |
         Recall  |
         Macro is prepared (or cued).  |
         Take  |
         Macro is taken.  |
         Recall and Take  |
         Macro is prepared and taken.  |
         Load project  |
         Project is loaded (Kahuna/Kula only). Warning: Load Project could affect the performance of the switcher. Use with caution during a running show.  |
The format of the text fields depends on the mixer chosen:
         Mixer  |
         Text field  |
         Remark  |
         Acuity  |
         One bank character and two macro characters.  |
         Recall (and Recall and take) only. Note that Device is named Custom Control instead of Macro Recall.  |
         Carbonite  |
         GV CPL  |
         Macro number (integer) in the range 1-999.  |
         Recall (and Recall and take) only.  |
         Kahuna/Kula  |
         The meaning and format of the text fields depend on the selected drop-down option:
         SONY SERIAL TALLY  |
         Macro number (integer) in the range 1-250.  |
         VIZRT-IPS  |
         Plays a macro having the name provided  |
         Take only  |
Note: Some Tricaster drivers use a non-standard macro in which the argument is the macro text itself. However, this does not apply the driver currently used by Viz Mosart.
Video Switcher Auxiliary Bus Delegation
Auxiliary bus delegation enables routing of internal video switcher signals to the auxiliary outputs of your video switcher.
Note: VIZRT-IPS: Video switchers supporting VIZRT-IPS use NDI outputs, not auxiliaries. So on the template, the Auxiliaries device is instead named NDI Router Output .
Type or select relevant values.
Guidelines for Auxiliary Bus Delegation Configuration
         Item  |
         Description  |
         BUS  |
         Selects the auxiliary to assign a new source.      Note: Newsroom tag available.  |
         XPOINT  |
         Crosspoint on the video switcher. Note: Newsroom tag available.  |
         AUDIOLINK  |
         Assigns a link group to this delegation. Please refer to Audio and Video Setup for the use of this feature.       |
         SET DELAY  |
         Set the delay in frames of the key delegation when taking the template to Program. If the field is left blank, the key is set in Preview  |
         TRANS DUR  |
         If the vision mixer has the ability to mix on the AUX channels, this is where the mix rate is set, 0 is a cut  |
Configuring an NDI Router (Viz Vectar Plus or Tricaster VMC)
Note: For NDI output crosspoints, you must refer to actual crosspoint names recognized by VMC1 (and not any user-friendly names that would be mapped to the physical inputs).
These default naming on the NDI router side is typically:
- INPUTn
- DDRn
- BFRn
- MIX n.
The same naming must be used on the Viz Mosart side.
In AV Automation > Devices > A/V Setup > Video Config > Mixer name column, you must provide the hardcoded name associated with the user-friendly name of the crosspoint.
This name is found on the switcher side.
In the example below, the value of the literal crosspoint name is the router output found in the switcher's Macro Configuration > Macro Editor menu and added to AV Automation:
There is a new setting UseOutputCrosspointNames in the IP-protocol config VizrtIpSystemsVideoSwitcherConfig.xml set by default to expect the crosspoint name, instead of the Viz Mosart standard of using physical input naming .
Keyfill: Video Switcher Key Bus Delegation
Video switcher key bus delegation enables routing of internal video switcher signals to the keyers on the different mixer effects of the switcher.
Note: VIZRT-IPS: For video switchers supporting M/E effects with 4 layers, the device is named Key/Layer.
To Enable Keyfill by Bus Delegation
Navigate to Enable > Keyfill > [Keyfill index]
To Enable Keyfill by Bus Delegation for M/E effects with 4 layers
Devices like Viz Vectar Plus or VMC1 let you configure M/Es with effects supporting up to 4 primary sources/input layers (along with Key layers), called A, B, C and D buses.
Viz Mosart can control these buses from a template or keyboard shortcut when
VIZRT-IPS
 is used for a vision mixer.
Navigate to Enable > KeyLayer > [KeyLayer index]
The Key/Layer device on a template can be used for VMC1 vision mixer to either set the crosspoint for a Key bus or to set the crosspoint for A, B, C and D buses of a M/E effect with 4 layers.
Right-click > Device properties.
Select from the BUS drop-down menu:-
If the device is used for setting the crosspoint for a key bus, set the BUS drop-down menu to a number between 1 and 8 on the Key/Layer device properties.
If the device is used for setting the crosspoint for a layer of a M/E effect with 4 layers, then choose one of the letters A, B, C and D from the BUS drop-down menu.
Guidelines for Keyfill Configuration
         Item  |
         Description  |
         BUS  |
         Selects the key bus on the selected ME.      If the video switcher supports M/Es with 4 layers (e.g. VIZRT-IPS), 4 more buses are available corresponding to each layer, A, B, C and D:      Note: Newsroom tag available.  |
         XPOINT  |
         Crosspoint on the video switcher. Default value: none Note: Newsroom tag available.  |
         AUDIOLINK  |
         Assigns a link group to this delegation. Please refer to Audio and Video Setup (previously Linking video and audio sources) for the use of this feature.       |
         MIXEFFECT  |
         Select the ME where the key crosspoint should be set.      Note: Newsroom tag available.  |
         KEY SET DELAY  |
         Set the delay in frames of the key delegation when taking the template to a program. If the field is left blank the key is set in preview.  |
         KEY ENABLE  |
         Key enable drop-down menu.      Note: Newsroom tag available.  |
Video Server
Guidelines for Video Server Configuration
         Setting  |
         Description  |
         SERVERCHANNEL  |
         The Mosart video port / port group where the clip is to be played out /recorded. For recording the corresponding video port has to be part of the “Rec” port group. Port groups are created as part of the video server configuration in menu AvAutomation > Devices > Preferences. In addition, the non-empty groups (groups with at least one port) are available.  |
         CLIP HIRESPATH  |
         The (default) clip ID or name. Note: Newsroom tag available, meaning that a value from the NRCS will override the value specified here.  |
         CLIP DESCRIPT  |
         You can enter a Clip description, however a clip description from the NRCS or video server overrides this value. Note: Newsroom tag available.  |
         TRIGGER START  |
         Enables the Trigger start function from control commands, a shortcut or continue point could be set to PLAY the Clip.  |
         RECUE CLIP  |
         In an A/B roll situation, when several Adlibs are played back-to-back, this setting determines how a clip will be restarted after it has been paused.  |
         LOOP  |
         Sets the server port to loop the clip. Beware! Not all video servers can loop.  |
         CUE ONLY  |
         Cues only the clip when the template is in Preview. The template will not start playing the clip when the template is taken.  |
Graphics
The Graphics device enables recall of graphic elements.
Graphic elements are cued (loaded) in Preview and played (started) when taken to Program.
Guidelines for Graphics Configuration
         Engine      |
         Selects the engine to operate on when using this template, based on your configuration.  |
         Content Source      |
         Send Continue on DVE FORWARD  |
         If selected, a continue command is sent together with a DVE Forward command.  |
         Use VizContentPilot  |
         Enable to run this element through a Viz Pilot client. This allows for OnLiveUpdate events in Viz Pilot data elements.  |
         Scene Name  |
         The default scene name is used, if not overridden by the NRCS. Note: Newsroom tag available.  |
         Scene Text  |
         The default scene text will be used, if not overridden by the NRCS. Note: Newsroom tag available.  |
         Is database Index  |
         Use take Out Command  |
         If selected, a take-out command is sent when the template status changes from On Air to Off Air.  |
         Take Out Delay  |
         Delay of sending takeout command after template status changes from On Air to Off Air.  |
         Translate Cue for Transition Logic elements  |
         If active, this setting overrides the global setting with same name set in AV Automation > Devices > Properties > Graphics > General > [VIZRT] > Miscellaneous. This setting only applies to transition logic for Vizrt full screen graphics. The Media Sequencer ignores standard cue command for these items.
Video Wall Register Recall
         Setting  |
         Description  |
         NAME  |
         Internal name of the shot.  |
         RECALL PREVIE  |
         For WATCHOUT, see notes below. For the other brands, this is the number of the recall to be taken when the template is cued in Preview.  |
         EMEMNR  |
         For WATCHOUT, see notes below. For the other brands, this is the number of the preset to take when the template is taken in Program.  |
The fields RECALL PREVIE and EMEMNR should contain the command or sequence of commands to be sent when the template comes in Preview or Program, respectively.
The general format is: [load "show"] [resetrun "timeline"]
Both load and run are optional, however at least one of them must be present. The show and timeline parameters may not contain double quotes.
The reset value is optional. For more information see the connection string property ResetAnyway, described in the section Video Wall Connection Strings.
In most cases, RECALL PREVIE contains load "show", and EMEMNR contains run "timeline".
Audio Player
LEVEL: This value does not affect the level. Instead, a value > -90 (the value must be an integer) starts playout, whereas a value <= -90 stops the playout.
AUDIO FILE: Optionally, enter an audio file name here. If a newsroom tag is added, and a value is provided by the NRCS, that value is used.
OUTPUT: (Viz Mosart Audio Player only) Choose the output on the Audio Player to be used, if nothing is inserted, the first port is used. This value is overwritten by values coming from the NRCS.
Outputs are displayed on the Audio Player UI (see the Audio Player section at AV Automation Devices > Audio).
        Note: Newsroom tags available for both AUDIO FILE and OUTPUT.
For further details, including third party audio players, see section Audio Players.
Virtual Set
You can specify the camera to take in a virtual set.
Insert the camera number in the virtual set that is to be taken when the template is taken to Program.
Note: For Vizrt's virtual set manager, Viz Arc, please refer to section Viz Arc AR Support in a Mosart Show.
Robotic Camera Control
The camera control device allows for recalling camera shots (and pre-programmed moves) when the template is cued in preview or aired in program. The device editor supports salvo recalls of shots by adding multiple lines for each shot recall.
The Template Device Functions are described below, as well as exceptions for specific camera types:
Guidelines for Standard Robotic Camera Control Configuration
         Shot Name  |
         Not used.  |
         Camera number  |
         Preview  |
         The exact meaning and format of the Preview fields depend on the type of camera robotics. (See the sections below.) These following three fields govern what happens when the template is taken in preview.  |
         Page Preview  |
         This field (together with Template Device Functions) determines the shot/move.  |
         Preset Preview  |
         Time preview  |
         This field (together with Template Device Functions and Template Device Functions) determines the duration of a move.  |
         Delay preview  |
         Not used.  |
         Program  |
         The exact meaning and format of the Program fields depend on the type of camera robotics. (See the sections below.) These following three fields govern what happens when the template is taken to air.  |
         Page program  |
         This field (together with Template Device Functions) together determine the shot/move.  |
         Preset program  |
         Fade time Program  |
         This field determines the duration of a move.  |
         Delay program  |
         Delay of move in Program (frames). Note: Only available for Vinten robotics systems  |
         Protect onair source  |
         Protected video switcher cross-point. If the video switcher cross-point is On Air, the shot/move recall will be ignored.  |
Cambotics Properties
Camera Number: Set camera number to 1.
Page Preview/ Page program: Robotic camera number.
Preset Preview/ Preset program: Shot number.
Time preview/ Fade time Program: [Optional] Duration for move in deciseconds (10 deciseconds = 1 second).
Note: All parameters not defined specifically, must be set to -1.
Camerobot Properties
Page Preview/ Page program: Name of shot’s matrix in preview/program.
Preset Preview/ Preset program: Shot’s cell number in the selected matrix - the shot is adjustable from NRCS and GUI.
Time preview/ Fade time Program: 0 ~ cut (fastest move) to position, ?0 ~ programmed move speed (adjustable from NRCS and GUI).
Cinneo System Properties
Page Preview/ Page program: Name of the camera to recall.
Preset Preview/ Preset program: Name of shot to recall - adjustable from NRCS/GUI.
Time preview/ Fade time Program: Desired moving time (seconds).
Fx-Motion Properties
Page Preview/ Page program: Identifies the camera to recall (identical to Camera Number > 0), optionally followed by :category for temporary overriding any NRCS or GUI settings.
Preset Preview/ Preset program: Name of shot or move to recall.
Time preview/ Fade time Program: =0 cut, <0 ~ default time to shot, >0 ~ wanted time (frames).
Panasonic Properties
Camera Number: Identifies the Controller that the command is linked to.
Page Preview/ Page program: Identifies the Camera Number to be controlled in Preview/Program.
Preset Preview/ Preset program: Identifies the Preset Stored Move in Preview/Program.
Time preview/ Fade time Program: Sets the Timed Delay in Preview/Program. Has no effect for Panasonic TCP.
Technodolly Properties
Page Preview/ Page program: Identifies the camera, identical to Camera Number when >0.
Preset Preview/ Preset program: Name of the move to recall.
Time preview/ Fade time Program: =0 ~ go to start of move, ?0 ~ move.
Shotoku TR_T Properties
Page Preview/ Page program: Page of shot to recall.
Telemetrics Properties
Page Preview/ Page program: Preset page number to recall.
Preset Preview/ Preset program: Preset number to recall.
Time preview/ Fade time Program: =0 cut, <0 ~ default time to shot, >0 ~ wanted time (seconds).
Vinten 200 Properties
Page Preview/ Page program: Name of the show to recall.
Time preview: <0 ~ go to end position of a move, = 0 ~ cut to shot, >0 ~ go to start position of a move, or move to a shot (frames).
Fade time Program: For moves, move forward or backward according to Time preview. For shots, = 0 ~ cut to shot, ?0 ~ move to shot (frames).
Electric Friends Robotic Camera
For Preview use:
Page Preview: Show and Robotic camera name separated with a colon (e.g.: ShowName:Cam 1).
Preset Preview [Optional]: Shot name. Shot attributes: prepare, prepareplay and loop. Separated with a colon (for example, prepare:ShotName and prepareplay:ShotName).
Time Preview [Optional]: Duration for move in frames. The time is rounded up to the nearest second.
For Program use:
Page Program: Show and Robotic camera name separated with a colon (e.g.: ShowName:Cam 1).
Preset Program [Optional]: Shot name. Shot attributes: prepare, prepareplay and loop. Separated with colon (for example, prepare:ShotName and prepareplay:ShotName).
Fade time Program [Optional]: Duration for move in frames. The time is rounded up to the nearest second.
GPO
The GPO editor is used for sending GPOs to external equipment.
The editor supports multiple GPO sends.
Add a new line in the editor for multiple GPO sends.Tip: For GPO values, refer to section GPIO.
gpo_preview: GPO to send when a template is cued in Preview.
gpo_program: GPO to send when a template is taken in Program.
Light Control
Note: The commands to use are driver-dependent and may vary.
Guidelines for Light Control Configuration
         Option  |
         Description  |
         PREVIEW COMMAND  |
         Command to use for the light mixer cue to be recalled when template is cued in Preview. Note: Newsroom tag available.  |
         PREVIEW VALUE  |
         Light mixer cue to use when template is cued in Preview. Note: Newsroom tag available.  |
         PROGRAM COMMAND  |
         Command to use for the light mixer cue to be recalled when a template is taken in Program. Note: Newsroom tag available.  |
         PROGRAM VALUE  |
         Light mixer cue to use when a template is taken in Program. Note: Newsroom tag available.  |
Preview Command and Program Command options are available from the drop-down list:
         Command  |
         Parameter count  |
         AllOff  |
         <none>. For details, see Set below.  |
         Fire  |
         1.For details, see Set below.  |
         Go  |
         cue number. For details, see Set below.  |
         GoOff  |
         Load  |
         NoteOff  |
         numeric note # (Std. MIDI command). For details, see Set below.  |
         NoteOn  |
         Reset  |
         Restore  |
         Resume  |
         variable. For details, see Set below.  |
         Set  |
         The value of SET is presented below in the context of Midi Show Control Specifications
 Note: You can include an optional time value ( key/value [/time]), in the form: key=value@hh:mm:ss:ff If unexpected program conditions occur,
use a (dummy) time parameter.   |
         Stop  |
         cue number. For details, see Set above.  |
         Custom  |
         SysEx bytesSend multiple custom SysEx bytes in the format \xnn where nn is a numeric value (0-255).  |
         TimedGo  |
         - (unsupported). For details, see Set above.  |
Router Control
The router control device allows setting crosspoints for source/destination pairs when the template is both cued in Preview and aired in Program.
Add new lines in the router device editor to support setting multiple crosspoints.
Guidelines for Router Control Configuration
         Item  |
         Description  |
         Source preview  |
         Source to route when a template is cued in Preview. Note: Newsroom tag available.  |
         Dest preview  |
         Destination of routing when a template is cued in Preview.  |
         Source program  |
         Source to route when a template is aired in Program.  |
         Dest program  |
         Destination to route when a template is aired in Program.  |
         matrix  |
         If the router system supports multiple matrices, select the matrix to use here.  |
         level  |
         program_delay  |
         Delay, in frames after the template has been taken to the air, for ‘program’ routing to happen.  |
         salvo_preview  |
         Salvo name to recall when a template is cued in Preview.  |
         salvo_program  |
         Salvo name to recall when a template is aired in Program.  |
Audio Faders
Guidelines for Audio Fader Configuration
         Remove Fader  |
         Removes the fader from the template.       |
         Order  |
         Re-arranging the order:
         Fader type  |
         Action: When a fader control is set as an action fader, the controls define whether the fader is enabled or disabled. Level: For normal operation.
         Link  |
         Assigns a video/audio link group to this fader.
         Keep level  |
         Keeps the fader level until manually changed.       |
         Fade up in preview  |
         Fades up the audio in preview, when camera is in program. Enabling this functionality only works with specific template combinations, as shown below:
         Input device  |
         Sets the type of the audio fader.
         Crossfade time  |
         Sets the in and out crossfade time for the fader.
         Manual close  |
         Select to ignore sending Close-level commands to audio mixer.       |
         Mode  |
         Only for Studer Vista and Lawo! Sends the chosen value to the mixer board for the audio fader.
         Delay  |
         Only for Studer Vista and non-Ember+ Lawo! Gives a delay value for that audio fader that will be sent to the audio board.
         Loudness  |
         Sends chosen recall value to send to the Junger audio processor.
