Viz Mosart User Guide
Version 5.0 | Published June 21, 2022 ©
On Air Shortcut Operations
images/download/attachments/85905810/image2019-8-21_22-35-7.png
Working with Template Shortcut Keys
  • You can speed-up access to operations that are defined in a template by assigning the template to a Viz Mosart shortcut key, by drag and drop.
  • All secondary items, including lower thirds and audio files in a template shortcut are are also added.
Template Shortcut Key Operations
To Add a Template Element to a Keyboard Shortcut Button
  1. From the Media Pool, drag an element from the Asset, Favorites or the Quick Access tab (see illustration above).
  2. Drop on a selected Viz Mosart shortcut key.
The selection is saved in your keyboards setup.
To Clear a Template Element from a Keyboard Shortcut Button
  1. Right-click on the button you wish to clear.
  2. Depending on the defined content either:
    1. From the context menu, choose Clear.
    2. Where secondary items are included, choose Clear sub items.
    3. Where NCS-bound keys are included, reset them to their original state by choosing Reset.
To Share Keyboard Shortcut Buttons between Viz Mosart Clients
You can share your keyboard shortcuts with other users connected to the same Viz Mosart system.
  • See Use Public Buttons in the topic Keyboard.
See also: Media Pool and General Settings.
