Viz Multichannel User Guide
GET Channel Settings for a Channel
Query Integrations Hub for a channels settings and their current values, using REST. Note: Query /channelsettings to get a full list of channels that have settings available, for proper discovery of the URI used in the example below.
Syntax
GET /channelsettings/[channelname]Request
GET /channelsettings/Channel1 HTTP/1.1Response
Example expected reply:
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshub+xml; type=channelsettings<channelsettings xmlns="http://www.vizrt.com/integrationshub"> <title>Channel Settings info for http://localhost:9990/channelsettings/Channel1</title> <name>Channel1</name> <link href="http://localhost:9990/channelsettings/Channel1" rel="self" type="application/vizrt.integrationshub+xml; type=channelsettings" /> <settingsversion>4.0.0</settingsversion> <setting name="GeneralSettings.BasicSettings.ChannelBasicInfo.ScreenDimension"> <value>1920*1080</value> </setting> <setting name="GeneralSettings.BasicSettings.ChannelBasicInfo.AspectRatio"> <value>16/9</value> </setting>[..] <setting name="GeneralSettings.BasicSettings.PlaylistDataMapping.ColumnDataMappings"> <value> <entry attributeName="begin_at" columnName="Begin Time" editable="true" /> <entry attributeName="duration" columnName="Duration" editable="true" name="entry#2" /> <entry attributeName="timecode" columnName="Offset" editable="true" name="entry#3" /> <entry attributeName="description" columnName="Description" editable="true" name="entry#4" /> <entry attributeName="event_id" columnName="Event ID" name="entry#5" /> <entry attributeName="trigger_id" columnName="Media ID" name="entry#6" /> </value> </setting>[..]</channelsettings>
