Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Choose Scene Type
images/download/attachments/29301342/builder_choose-scene-type-new.png
When launching the Map Builder you will be presented with the following options:
  • Navigator: Allows you to build a scene with one starting point and up to 32 destinations.
  • Focus on Map: Allows you to create a static scene with a base map only. Can only be used with flat geometries.
  • 1 Destination: Allows you to build a scene with one starting point and one destination.
  • Map Object: Allows you to build a scene with one starting point and one destination. The window option is used so that the map only uses part of the screen.
  • Open: Opens existing map template files.
