Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Map Projection
images/download/attachments/29301944/classic_properties_projection_globe.png
An essential setting for 3D globe building in Viz Artist is To set the map projection to an equidistant cylindrical projection (also known as equi-rectangular or geographic projection). When using the map on a 3D globe in Viz Artist it will give the right (or more correct) representation of the world.
Note: In Viz Artist vertex mapping should be used when creating 3D globes.
Wrong and correct projection
images/download/attachments/29301944/classic_projection_wrong.png
Using the wrong projection within Viz Artist, for example, with the Map Tiler plugin to build a 3D globe, will produce a distorted projection.
  1. Select the Properties tab.
  2. From the Projection drop-list select the Cylindrical Equidistant projection.
  3. Select “The World” from the View drop-list (lower-right corner) to check that the map is a flat and not a globe view of the World.
  4. Click Apply.
    Note: This test also works well via the WME in Viz Artist, and so on.
