Viz World User Guide
Version 17.0 | Published March 11, 2019 ©
Working with the OSM Downloader
To install the OSM Downloader
The OSM Downloader must be installed alongside the Viz World Server. This is done by installing Viz World Client components on the server.
  1. Run the Viz World Client installer
  2. Select Custom
  3. Select the Viz World Server Config component
  4. Click Next
  5. Click Finish
To configure the OSM Downloader
Before the open street maps can be downloaded and used by your designers you need to configure the Street Data location.
Tip: Both tools can be started from: C:\Program Files\vizrt\Common\Maps
  1. Run the Viz World Server Configuration tool
  2. Connect to your map server
  3. Select the Maps -> Locations section to configure the Street Data location
  4. Run the OSM Downloader tool
  5. Set the Destination folder to match the Street Data location
To download open street maps
Before you start to download open street maps you need to have a Vizrt FTP account, aswell as have the software installed and configured.
  1. Run the OSM Downloader tool
  2. Make sure you have a connection to your map server
  3. Enter your Vizrt FTP account credentials and click Connect
  4. Browse and select data
  5. Click Add images/s/en_US/7901/119ca25093da5dbe5f504cc7d71e386a1aab2736/_/images/icons/emoticons/add.svg to add data to your download queue
  6. When done, click Download
Tip: Before attempting to connect, make sure the destination folder is configured correctly to match whats configured for Street Data location in Viz World Server configuration, and user has write privilege to that folder.
