Dell R7920
images/4391e71870d01f5212fa241e02471baf9da84db1eaa22830f35f380b5d5adddc.dat
Dell R7920 Rack Workstation Slots
images/download/attachments/41803527/image2018-6-12_12-16-21.png
Slot
Usage
Slot 1 – PCIe3 x8
Graphics Card only! (Single / Dual Slot)
Slot 2 – PCIe3 x8
Used if a Dual-Slot Graphics Card is installed
Matrox AES Audio
Slot 3 – PCIe3 x8
Video Card (i.e. Matrox Video Board)
Slot 4 – PCIe3 x16
Expansion Cards:
Matrox AES Audio
Blue Storm
SeaLevel
Slot 5 – PCIe3 x8
Video Card (i.e. Matrox Video Board) (if two Graphics Cards are installed)
Slot 6 – PCIe3 M2 SSD
PCIe M.2 SSD
Slot 7 – PCIe3 x8
Slot 7 – PCIe3 x8
Second Graphics Card
Note: Only Matrox boards have been tested.
BIOS Settings
  • During Post, press F2 to get access to the BIOS Setup.
    • Click on System BIOS.
    • Click on Processor Settings.
    • Set Logical Processor to DISABLED.
    • Press ESC to Exit Menu.
  • Click on SATA Settings.
    • Set Embedded SATA to RAID MODE.
  • Click on NVMe Settings.
    • Set NVMe Mode to NonRAID.
  • Click on Boot Settings.
    • Check if Boot Mode set to UEFI.
  • Click on Integrated Devices.
    • Set Embedded Video Controller to DISABLED.
  • Click on System Profile Settings.
    • Set System Profile to Performance.
    • Press ESC twice, Settings are saved.
  • Exit Bios.
  • Press F2 to access BIOS.
  • Change Boot Order (C should be at top).
  • Save Changes and Exit.
Only newer Matrox Boards like xMio3 and DSX.LE4 are supported with Dell R7920 workstations. Older videoboards are not tested by Vizrt.
Certain third party vendor drivers require secure boot to be disabled to install properly.
