Video Output
Use the Video Output section to configure special settings for video output, such as SPG settings and so on.
Note: The VGA version of Viz Engine does not have this section.
Video Output Properties (1)
images/download/attachments/41803360/video-output-with-editor.png
  • Show Video Output Config. Editor: Opens the Video Output Editor (2). You can also open the Video Output Editor by pressing Alt+V.
  • Video wall/Multi-display: Sets the main output to the Digital Visual Interface (DVI).
    Important: For videowall setups, this setting must be active and the output format must be set to FULLSCREEN.
  • Streaming Output: Activates or deactivates IP Streaming output.
  • Render preview default setting: Sets the default value for the Preview button (see Control Buttons ) when Viz Engine is in On Air mode.
    • Inactive: Renders only video out signals. This increases performance, as the renderer does not have to render into an editor on-screen and into pixel buffer.
    • Active: Renders both video out signals and on-screen (this decreases performance).
    • Fullscreen: Sets the On Air window to screen size.
Video Output Editor
The Video Output Editor defines the synchronization standard and the output signal phases.
images/download/attachments/41803360/image2018-12-11_11-22-50.png
  • Freerun: Locks Viz Engine to a clock signal on the video board.
  • Blackburst: Locks Viz Engine to a Blackburst GenLock signal.
  • Tri-level: Locks Viz Engine to a Tri-Level GenLock signal.
  • Auto: Auto detects the genlock signal and locks to it.
  • Digital Input 1 and 2: Locks Viz Engine to the signal on Input 1 or 2.
  • PTP: Uses a Precision Time Protocol source for synchronizing. Mainly used in IP networks.
  • H-Phase and V-Phase: Shifts the output signal with respect to the sync signal.
    Note: The Auto option is only available on Matrox boards . On Matrox boards the h- and v-phase settings are updated automatically as well.
To Make the V- and H-Phase Values Coincide
  1. Set the V-phase value
    • The V-granularity is taken from the genlock.
    • The V-delay is calculated from V-phase * V-granularity.
    • The genlock is set with this V-delay.
  2. Set the H-phase value. Note that there is a distinction whether the H-phase is a positive or a negative value.
    1. If the H-phase > 0
    • The genlock H-delay is set to 0.
    • The H-granularity is taken from the video out channel.
    • The H-delay is calculated from H-phase * H-granularity.
    • The fill and key channels are set with this H-delay.
    1. If the H-phase <=0
    • The fill and key channel H-delay is set to 0.
    • The H-granularity is taken from the genlock.
    • The H-delay is calculated from - H-phase * H-granularity.
    • The genlock is set with this H-delay.
      Note: The granularity and possible min/max values are printed to the Viz Artist/Engine console during startup.
It should be taken into account that when the genlock video format is different from the fill/key video format the value of the V-delay matches the genlock lines and not the video output lines. The same applies to negative H-phase values.
