SNMP Viz Engine OIDs
This document lists all available OIDs for Viz Engine. N represents the current channel, that is 1 is for Viz Engine Channel 1 (first instance)
Viz Engine OIDs
Value OID
Description
Type
Info
27566.1.1.1.N.1
Ready For Connect
TruthValue
Viz Engine is initialized and running (On Air or off air)
27566.1.1.1.N.2
On Air
TruthValue
Viz Engine is On Air
27566.1.1.1.N.3
Connected To Db
TruthValue
Viz Engine is connected to Viz Graphic Hub
27566.1.1.1.N.4
Post Render Mode
INTEGER normalmode(0), postrendermode(1)
Post render mode active
27566.1.1.1.N.5
NLE Mode
INTEGER normalmode(0), nlemode(1)
NLE mode active
27566.1.1.1.N.6
Current Frame Rate
Integer32 (0..10000)
Current frame rate
27566.1.1.1.N.7
Retrace Counter
Integer32 (0..65536)
Changing number when the engine is rendering
27566.1.1.1.N.8
Viz Engine Version
OCTET STRING (SIZE (0..128))
Version string
27566.1.1.1.N.9
System ID
Dongle ID
27566.1.1.1.N.10
Computer Type
INTEGER irix(0), video(1), panasonic(2), pc(3), twc(4), sgipc(5), chyron(6), unknown(7)
27566.1.1.1.N.11
TCP Port
TCP command port, 6100 or similar
27566.1.1.1.N.12
Genlock Status
INTEGER ok(0), wrongformat(1), bad(2), droppedframes(3), unknown(4), notavailable(255)
Genlock status
27566.1.1.1.N.13
Video In 1 Status
Video input status
27566.1.1.1.N.14
Video In 2 Status
27566.1.1.1.N.15
Video In 3 Status
27566.1.1.1.N.16
Video In 4 Status
27566.1.1.1.N.17
Video In 5 Status
27566.1.1.1.N.18
Video In 6 Status
27566.1.1.1.N.19
Video In 7 Status
27566.1.1.1.N.20
Video In 8 Status
27566.1.1.1.N.21
Clip 1 Status
Clip status
27566.1.1.1.N.22
Clip 2 Status
27566.1.1.1.N.23
Clip 3 Status
27566.1.1.1.N.24
Clip 4 Status
27566.1.1.1.N.25
Clip 5 Status
27566.1.1.1.N.26
Clip 6 Status
27566.1.1.1.N.27
Clip 7 Status
27566.1.1.1.N.28
Clip 8 Status
27566.1.1.1.N.29
Texture Memory Free
Integer32 (0..2147483647)
Texture memory available in KB
27566.1.1.1.N.30
Texture Memory Total
Total texture memory in KB
27566.1.1.1.N.31
Texture Memory Used
Integer32 (0..100)
Texture memory used in %
27566.1.1.1.N.32
Renderer Scene Front
OCTET STRING (SIZE (0..1024))
Scene name
27566.1.1.1.N.33
Renderer Scene Middle
Scene name
27566.1.1.1.N.34
Renderer Scene Back
Scene name
27566.1.1.1.N.35
Post Scene Front
Scene name
27566.1.1.1.N.36
Post Scene Middle
Scene name
27566.1.1.1.N.37
Post Scene Back
Scene name
27566.1.1.1.N.38
Retrace Counter Moving
TruthValue
Computed flag; true if the retrace counter changes. Can be possibly used to detect hanging renderer
Viz Engine Trap OIDs
On change of some of the important properties a trap (notification) is generated too. This way the monitoring system which is polling the values at regular intervals gets the change immediately. Persisting “failed” values trigger repeated traps.
Trap OID
Description
Value OIDs Included
Info
27566.1.1.1.N.0.1
Ready For Connect Changes
27566.1.1.1.N.1
Sent when state changes or periodically if value is false
27566.1.1.1.N.0.2
On Air State Changes
27566.1.1.1.N.2
Sent when 27566.1.1.1.N.2 is true and state changes or periodically if value is false
27566.1.1.1.N.0.3
Db Connection State Changes
27566.1.1.1.N.3
Sent when 27566.1.1.1.N.3 is true and state changes or periodically if value is false
27566.1.1.1.N.0.4
Genlock State Changes
27566.1.1.1.N.12
Sent when 27566.1.1.1.N.12 is true and state changes or periodically if value is not 0
27566.1.1.1.N.0.5
Texture Memory Changes
7566.1.1.1.N.29-31
Sent when 27566.1.1.1.N.29-31 is true and state changes or periodically if value is < 10000 KB (hardcoded)
27566.1.1.1.N.0.6
Retrace Counter Changes
27566.1.1.1.N.38
Sent when 27566.1.1.1.N.38 is true and state changes or periodically if value is false
27566.1.1.1.N.0.7
Renderer Front Scene Changes
27566.1.1.1.N.32
Sent when 27566.1.1.1.N.32 is true and state changes
27566.1.1.1.N.0.8
Renderer Middle Scene Changes
27566.1.1.1.N.33
Sent when 27566.1.1.1.N.33 is true and state changes
27566.1.1.1.N.0.9
Renderer Back Scene Changes
27566.1.1.1.N.34
Sent when 27566.1.1.1.N.34 is true and state changes
