Viz Multichannel
Configuration Interface
images/download/attachments/30906130/configuration_settingsbutton.png
Viz Multichannel settings are split in two distinct categories: Global and Channels where channels are the various channels that have been defined by the user in Viz Multichannel.
  • Global settings apply to all channels.
  • Channel settings define the output channels connected to your scheduling system.
    Most of the configuration work is done on a per channel basis. When configuring your channel settings, ensure that you have selected the required channel beforehand. Most settings are set using the Settings window.
    images/download/attachments/30906130/CPE.png
This section presents the following topics:
