Viz Multichannel
GET Playlist from a Channel
To obtain a collection of playlists associated with a given channel with links to each, use the following GET command. The command will obtain a full representation of the playlist's header and a full list of primary elements with a limited set of data and links to each primary elements.
Syntax for GET
GET /restapi/[channel_name]/[playlist_name]
Example Request
GET /restapi/Channel1/continuous HTTP/1.1
Example Response
HTTP/1.1 200 OK
Content-Type: application/vizrt.integrationshub+xml; type=playlist
<playlist xmlns="http://www.vizrt.com/integrationshub">
<title>Playlist info for http://localhost:9990/restapi/Channel1/continuous</title>
<description>Continuous Playlist</description>
<name>continuous</name>
<link href="http://localhost:9990/restapi/Channel1/continuous" rel="self" type="application/vizrt.integrationshub+xml;type=playlist" />
<broadcast_date>continuous</broadcast_date>
<group>
<description>Schedule1</description>
<name>1958a5d9-87bb-42f0-a208-5ea7968c7649</name>
<link href="http://localhost:9990/restapi/Channel1/continuous/1958a5d9-87bb-42f0-a208-5ea7968c7649" rel="self" type="application/vizrt.integrationshub+xml;type=group" />
<begin_at>2017-08-28T10:00:00.000Z</begin_at>
<duration>5289.12</duration>
<event_id>1001</event_id>
<trigger_id>1</trigger_id>
<take_count />
</group>
<group>
<description>Despicable Me 2</description>
<name>b536b347-ad9a-4ff7-9fb7-b097cd4b8230</name>
<link href="http://localhost:9990/restapi/Channel1/continuous/b536b347-ad9a-4ff7-9fb7-b097cd4b8230" rel="self" type="application/vizrt.integrationshub+xml;type=group" />
<begin_at>2017-08-28T11:28:09.120Z</begin_at>
<duration>300</duration>
<event_id>1002</event_id>
<trigger_id>2</trigger_id>
<take_count />
</group>
<group>
<description>The Incredible BURT WONDERSTONE</description>
<name>d84ac0fc-bcbe-4a8a-a134-6ff0384ac8e0</name>
<link href="http://localhost:9990/restapi/Channel1/continuous/d84ac0fc-bcbe-4a8a-a134-6ff0384ac8e0" rel="self" type="application/vizrt.integrationshub+xml;type=group" />
<begin_at>2017-08-28T11:33:09.120Z</begin_at>
<duration>3525.04</duration>
<event_id>1003</event_id>
<trigger_id>3</trigger_id>
<take_count />
</group>
<group>
<description>Man of Steel - Official Trailer 3</description>
<name>63e76944-f62e-4c24-b425-15fd603942b0</name>
<link href="http://localhost:9990/restapi/Channel1/continuous/63e76944-f62e-4c24-b425-15fd603942b0" rel="self" type="application/vizrt.integrationshub+xml;type=group" />
<begin_at>2017-08-28T12:31:54.160Z</begin_at>
<duration>181.12</duration>
<event_id>1004</event_id>
<trigger_id>4</trigger_id>
<take_count />
</group>
<ischannelpool>false</ischannelpool>
</playlist>
