Viz Multichannel
Main Menu and Toolbar
images/download/attachments/30906005/MainMenu.png
From the top the Viz Multichannel user interface offers you a main menu and below it a dynamic (configurable) toolbar.
A dynamic toolbar means that you can configure which icons (representing actions) that should be available in the toolbar. You configure which icons to display under Actions from the main menu.
The actions themselves will be available as keyboard shortcuts, for example F9 and Ctrl-F9 to take or take-out the Logo-page, even if the icons representing the actions are not displayed.
Main Menu
  • File
    • Exit: Closes the application
  • Tools
    • Analyze logs: allows you to open and analyze the As Run Logs. The As Run logs offers an easily readable overview of all elements run by the system. The logs are created by the Media Sequencer.
    • Reports Manager: allows you to create reports on multiple channels.
    • Generate Channels File: Generates a file containing information about channels file. This is required when running Viz Multichannel in MCR mode (see Master Control Workflow).
  • Action
    • Edit Mode: enable edit mode
    • Cleanup Engines: clears all loaded graphics from memory on the program and preview renderer's for the output profile currently in use. It should be used before initializing a new playlist or in order to re-initialize the same playlist into the renderer’s memory. Note that cleanup commands will affect all clients that are connected to the same Media Sequencer, and using the same output profile (see Clear Layers).
    • Clear Layers: allows you to clear all or specific layers (i.e. front, middle or back) for your channel’s configured Viz Engines. Note: This will still leave the graphics in memory (see Toolbar and Cleanup Engines).
    • Initialize: use this option to manually initialize either the currently selected Channel or the Channel Pool. Initializing will fetch and load resources to the memory of the Viz Engine ensuring resources such as graphics are ready for playout. If not initialized, the Viz Engine will still load resources when needed, but pre-fetching can in certain situations be appropriate for flicker and artifact-free playout.
    • Logo Page: allows you to take or take out the defined logo page.
    • Error Page: allows you to take or take out the defined error page.
    • Video-only Page: allows you to take or take out the defined video-only page.
    • Ticker: allows you to import or export Viz Ticker3D playlists (see Working with Ticker Actions).
    • Actions: allows you to import or export actions from an XML-file.
    • Template and Pages: allows you to import or export template and pages to XML-files.
    • Campaigns: Allows you to import or export Campaigns.
    • Video bypass: When enabled, only video is shown. When disabled, video and graphics are shown.
  • Help
    • Help (F1): Launches the documentation in your preferred browser.
    • About: Shows the version of Viz Multichannel.
Toolbar
Icon
Shortcut
Description
images/download/attachments/30906005/icons_icon_settings.png
Configuration menu
images/download/attachments/30906005/userinterface_icon-engine.png
Local Viz Engine status. Sub-Commands that can be selected: Show Commands, Show Status and Restart Viz. Note that these commands will be sent to the local Viz Engine, normally used for preview. For more information about any given status, see the log messages in your Information Panel.
images/download/attachments/30906005/image2017-7-17_18_20_12.png
Profile settings - click this icon for the Playout Configuration dialog where you can add playout devices and device channels.
images/download/attachments/30906005/userinterface_clock.png
Shows the time of the currently selected channel’s Media Sequencer server, with the local client (Multichannel UI) machine offset applied. Example: If the Media Sequencer machine is UTC and it is 12.00 and UI is CET (UTC+1), then the clock will show 13.00. Click the clock icon to show the Media Sequencer machine time with only the local offset and timezone-offset applied. Given the data in the example above, the time shown is now 12.00, and the time-zone info shown is UTC+0.
images/download/attachments/30906005/icons_vizengine_takelogopage.png
F9
Take in the defined Logo Page.
images/download/attachments/30906005/icons_vizengine_takelogopage_out.png
Ctrl-F9
Take out the defined Logo Page.
images/download/attachments/30906005/icons_vizengine_takeerrorpage.png
F10
Take in the defined Error Page.
images/download/attachments/30906005/icons_vizengine_takeerrorpage_out.png
Ctrl-F10
Take out the defined Error Page.
images/download/attachments/30906005/icons_vizengine_videoonly.png
F11
Take in the Video Only Page.
images/download/attachments/30906005/icons_vizengine_videoonly_out.png
Ctrl-F11
Take out the Video Only Page.
images/download/attachments/30906005/icons_icon_import_tickert.png
Import a Viz Ticker definition file (XML)
images/download/attachments/30906005/icons_icon_export_tickert.png
Export a Viz Ticker definition file (XML)
images/download/attachments/30906005/icons_icon_import_actions.png
Import Actions definitions (from XML file)
images/download/attachments/30906005/icons_icon_export_actions.png
Export Actions definitions (to XML file)
images/download/attachments/30906005/icons_icon_import_templates_and_pages.png
Import Templates (and Pages) from the connected Graphics Hub
images/download/attachments/30906005/icons_icon_export_templates_and_pages.png
Export Templates (and Pages) to the connected Graphics Hub
images/download/attachments/30906005/icons_icon_import_campaigns.png
Import Campaigns (to XML file)
images/download/attachments/30906005/icons_icon_export_campaigns.png
Export Campaigns (to XML file)
images/download/attachments/30906005/icons_icon_enable_hw_video_bypasss.png
Enables the mechanical bypass on the Matrox video card. This effectively bypasses any rendering and stops the Viz Engine from impacting the video signal. Important: for this to work, the Viz Engine must be properly configured. See the Matrox and Watchdog sections in the Viz Engine Administrator's Guide.
images/download/attachments/30906005/icons_icon_disable_hw_video_bypasss.png
Disables the mechanical bypass on the Matrox video card. This effectively bypasses any rendering and stops the Viz Engine from impacting the video signal. Important: for this to work, the Viz Engine must be properly configured. See the Matrox and Watchdog sections in the Viz Engine Administrator's Guide.
