![](assets/images/logos/GraphicHub.png)
Version 3.1 | Published July 11, 2018 ©
Copy to Target Folder Only
The image, below, shows the settings to deploy a folder from the source server to folder T on the destination server in Copy to target folder only mode.
In this case the structure of the source server is ignored and all files from the source folder, and its sub-folders, are copied directly into folder T.
The image, below, shows that only files were deployed to folder T, and no sub-folders were created.
Note: Referenced files outside the source structure will also be deployed into the target folder. Since there might be files from multiple folders deployed into a single folder, it is possible that the target folder will contain multiple files with the same name.
