![](assets/images/logos/GraphicHub.png)
Version 3.1 | Published July 11, 2018 ©
Graphic Hub Deploy Agent
The method to copy and synchronize a database is the Direct Deploy Copy (DDC) functionality.
The Graphic Hub deploy solution makes it possible to copy folders/projects/files with all necessary data (referenced folders/projects/files) from one server to another. For example, if a scene is to be deployed, all files that are referenced by this scene (images, materials, and so on) will also be deployed.
The Deploy Agent enables the configuration of scheduled deploy tasks, and is run from the Graphic Hub Manager.
