AV Automation Devices Audio
Viz Mosart is capable of connecting a variety of Audio Mixers available from several different manufacturers.
Select the correct Audio Mixer from the menu for your broadcast environment. AV Automation handles the following:
Audio Mixer
images/download/attachments/72109017/configuration_avauto-audiomix-setup-window.png
  • Use Audio mixer: Enables the audio mixer functionality.
    • Audio mixer type:
      Audio mixer
      Protocol
      Supported hardware
      Interface
      Calrec
      RAP
      RS-422, TCP/IP (Artemis)
      DHD
      DHD RM4200-D v2.02
      TCP/IP
      EUPHONIX
      RAP
      COM
      LAWO RMNOPL
      RemoteMNOPL
      Lawo mc²
      TCP/IP
      LAWO ZIRKON
      RAS, Lawo Zirkon subset
      RS-422 or TCP/IP
      MIDIMIXER
      Sanford.Multimedia
      MIDI
      SSL
      Light Broadcast Automation protocol, SSL Broadcast Automation Control Specification – v1.0
      RS-422 or TCP/IP
      STAGETEC
      Stagetec Diamond RAS protocol, Monitora RAS
      COM
      STUDER_3000
      Monitora + Ember, Ember 1.0
      Studer OnAir 3000
      RS-232 or TCP/IP
      STUDER_VISTA
      Ember
      Studer Vista
      TCP/IP
      VIZENGINE
      n/a
      Viz Opus only
      TCP/IP
      WHEATSTONE
      Wheatstone Mixer Automation Protocol v.1.4
      TCP/IP
      YAMAHA_O2
      MIDI
      Yamaha 01V96, DM1000, DM2000, DME64N, O2V96, LS9, CL5
      MIDI
      vizrt-ips
      NewTek
      Vizrt Group/NewTek ip series mixers. TriCaster, VMC, Viz Verdi, Viz Vectar
      TCP/IP
  • Serial (Calrec, Lawo, Studer, etc.): Serial port connected to the audio mixer (when Serial radio button is selected).
  • TCP/IP: Hostname (or IP address) and port to communicate with the audio mixer (when TCP/IP radio button is selected).
  • Backup hostname and port (Lawo): Hostname (or IP address) and port to the backup audio mixer console.
  • Set user labels on console: When selected, user labels on the Lawo or Vista console are overwritten.
  • MidiCh (Yamaha): MIDI channel assigned to the audio mixer.
  • Midi Output port (Yamaha): System MIDI port to communicate with the audio mixer.
  • Default fade time: Time in frames for fading open faders with the manual fade function (CTRL+F).
  • Default snapshot: Snapshot to recall when starting the automation (MIDI parameter change).
  • Audio effect server: Name for the Audio effect fader. This fader will open if effect transitions are used.
  • Send reset command on connect: Used for STUDER3000 SW 2.2, or lower. Recalls a default setup for the Mixer panel.
  • Visible audio faders: Maximum visible faders in AV Automation.
  • Use sound player: Enables connection to the Audio Player.
  • Host: Hostname or IP address to the computer running the Audio Player.
  • Default directory: Directory for the audio files (on the Audio Player’s PC).
AV Automation Audio Mixer Compatibility Table
CAL REC
DHD
LAWO RMNOPL
LAWO ZIR KON
SSL
STAG ETEC
STUDER 3000
WheatStone
YAMAHA O2
STUDER VISTA
EUPHONIX
vizrt-ips
Serial
x
x
x
TCP/IP
x
x
x
x
MidiCh
x
Midiport
x
Hostname
x
x
x
x
x
x
x
x
x
Port
x
x
x
x
x
x
x
x
x
x
Backuphost name
x
BackupPort
x
Faderinputoffset
x
Useemberprotocol
x
Comportaudiomixer
x
x
x
x
x
x
Loudness Control
images/download/attachments/72109017/configuration_avauto-loudness.png
  • Use loudness controller: Check the box to enable loudness control.
  • Loudness controller type: JUNGER T*AP.
  • Triggers/levels: Name of triggers or loudness levels, one for each line. These will appear in a tool-tip menu in the Template editor, and must correspond to the configuration in the loudness controller(s).
  • Channels: Fixed values. For Junger T*AP there are four stereo channels per host. Connections to the audio faders are configured in A/V Setup/Edit/Audio config/Loudness channel.
  • Host:port: Hostname or IP address and optional port number for each controller.
