td_templatedescription
The table td_templatedescription contains template information to be presented to users that may differ among the galleries (i.e. this information is gallery dependent).
Name
Type
Allow Null
Description
td_recno
integer
No
Primary key.
td_te_recno
integer
No
Foreign key referencing the corresponding template te_recno in the te_template table.
td_ga_recno
integer
No
Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table
td_tr_recno
integer
Yes
Optional foreign key referencing a transition tr_recno in the tr_transition table.
td_default
varchar(128)
Yes
Optional default value for transitions not of type ENUMERATION. Normally for MIX and WIPE transitions.
td_em_recno
integer
Yes
Optional foreign key for the default value for ENUMERATION transition types. Normally EFFECT transition. Reference to a enumeration value em_recno in the em_enumerationmember table.
td_descriptionupdateddate
Datetime
No
(deprecated)
Note that the overall template description is stored in three parts / tables:
  1. td_templatedescription: The base template description.
  2. tr_transition: The transition used by the template. In Mosart this equals the transition when taking the template. Normally either Mix, Wipe or Effect.
  3. tdfi_connection: Relation that list all fields (or newsroomtags) used by the templates. A newsroomtag is a template property allowing users to input information to the template. Normally newsroomtags are exposed to the users in the NCS.
