Manus Administrator Commands
These console commands are only intended for advanced users, and principally for troubleshooting. They shall never be used on a live system.
Warning: Use of these commands may adversely affect system performance. Unauthorized use of these commands may invalidate a contracted Vizrt Support agreement.
DUMPNCSRUNDOWN DNR /p[destination filepath]: Dumps the current rundown in the native NSML format
DUMPNCSSTORY, DNS [storyname] /p[destination filepath]: Dumps a story in native NSML format
-FILEWATCHER -FW: Starts the application in file watcher mode
Go to next story
HIDELOG: Hide logging elements
INEWSDEFAULTRUNDOWN: Sets the defaultShowpath
INEWSFTPSERVER [servername] [username] [pathword] Sets the ftp connection to inews FTP server. You must restart GTS or G
INEWSWORKINGDIRECTORY: Sets the working directory
INIFILEPATH Sets the ini file
LISTCLIPS: List all items in media cache
LM, LOADMANUS [filename]: Loads manus from file
LOG: Collect logs for all connections
LOG [filename]: Write current log to file
NEWSROOMSETTINGS,NS: Show settings dialog for newsroomsettings
NEWT: Send Mosart templates to NCS as MOS objects with status NEW (T emplates which are not marked “Send to NCS” in the Template properties, will not be sent to NCS)
NONEAUTOS: List non-auto lowerthirds
PARSENATIVESTORY,PNS: Parses a native NCS file to Mosart XMLPS [0] [0]
pcol: Print col1
PRINTRUNDOWNS: Print newsroom rundowns
PST: Print states
PRINTSTORY: Print story or story item
R: Release Background
READSPEED [0]: Set read speed in words per minute
RELOADMANUS, RL, RELOAD: Reload current manus
RELOADTEMPLATES, RT: Reload ChannelTemplates
RESYNC-resync: Resync rundown with NCS
S: Skip next story
SAVE [path]: Save the rundown as a file.
SAVEASSEQUENCE [sequencename as string]: Save the rundown as a sequence
setManusDirectory: Set the directory in which manus are stored
setrundown, SR, CD [name]: Set a new rundown
SETTINGS: Show settings dialog
SHOWLOG: Show logging elements
SS, STUDIOSETUP: Set the current studiosetup
START: Start or stop the timeline
STEST: Start a series of automatic tests. Y to start, N to stop. (millisec).
TESTUPDATE: Start test timer
tmpPrint: Print the manus
TRACE: Activate/deactive the trace listener
UPDT: Send Mosart templates to NCS as MOS objects with status UPDATED (Templates which are not marked “Send to NCS” in the Template properties, will not be sent to NCS)
VERSION: Print the current version
WQ: Write queue list
