Video Server, MAM and Database Connection Strings
A connection string contains parameters needed for connecting a studio device to Viz Mosart. The string always comprises two parts:
  • Standard Settings
    For example Name, Type, Server, Config (the name of the associated file that contains Custom Settings)
  • Custom Settings
    Driver-specific configurations. For example, what to log in error situations, manipulation of standard commands, or timeout behavior.
Connection strings are used both in the Media Administrator Configuration and, in some cases, AV Automation . In AV Automation connection strings get auto-generated when configured in the Video Server GUI. In AVAutomation, you can also enter additional device parameters to match specific control room parameters.
Standard Connection String Properties
Irrespective of device type, several values are standard parameters.
Viz Mosart Video Server Connection String
Name=myServerName; Type=myServerType; Server=myServerAddress; Config=myConfigFile.xml
  • Name: A logical name consistently associated with the device, allowing the device to be uniquely recognized throughout the system setup.
    All Media Administrator connection strings contain a name , which forms a distinction for Media Administrator, when handling multiple clip metadata sources and video servers.
    If the same video server also is to be controlled by AVAutomation, the Name in AVAutomation should be the same as here.
  • Type: Specifies which driver to be used for connecting to the server. See the table below for details about which Video Server Drivers that are currently supported.
  • Server: Specifies the server name or the IP address of the video server.
  • Config: Specifies a configuration file containing custom configuration for a particular video server driver. Editing these files is typically done during installation.
  • Static: (Effective for Media Administrator only) If True, Media Administrator always connects to this MAM system (or video server), also when Enable dynamic configuration (see Media Administrator Properties Editor, Configuration) is True, and this MAM system (or video server) is not part of the salvo selected in AV Automation (see AV Automation Devices Video Servers, Virtual Server Ports). (Normally, a MAM system will not be part of any salvo, so this setting is mostly used for MAM systems which should always be connected, regardless of the selected salvo.) Default False.
  • AirSpace: AirSpace video driver.
  • AirSpeed: AirSpeed video driver.
  • AirSpeedSearch: As AirSpeed driver, but contains search functionality only. Used by Media Administrator to obtain clip status from an AirSpeed video server.
  • AirSpeedMultiStream: AirSpeed Multi Stream driver, also Airspeed 5000.
  • AirSpeedMultiStreamSearch: As AirSpeed Multi Stream driver, but contains search functionality only. Used by Media Administrator to obtain clip status from an AirSpeed Multi Stream or 5000 video server.
  • Amadeus: Amadeus MAM driver.
  • EVS: EVS driver.
  • GrassValleyK2: Grass Valley K2 driver.
  • OPUS: Omnibus MAM driver using OPUS interchange.
  • Omneon: Omneon video driver.
  • OmneonSearch: As Omneon driver, but contains search functionality only. Used by Media Administrator to obtain clip status from an Omneon video server.
  • Quantel: Quantel video driver.
  • ScreenLLSearch: Screen LinguaLib search driver.
General Configuration File Properties
  • VerifyClipDelay (integer): Delay in frames to wait before verifying new clips from server.
  • KeepCache (boolean): When set to true, the internal Media Administrator clip cache is kept on reconnect (Default=False).
  • RefreshOnUpdate (boolean): If set to true, any clip update message received from the video server results in a clip refresh operation (Default=False).
  • ReleasePortOnDispose (boolean): If true, the assigned video port is released when server connection is closed (Default=True).
  • SupportSearchUsingObjSlug (boolean): Activates searching using objSlug (Default=True).
  • SupportSearchUsingRefID (boolean): Activates searching using RefID (Default=False).
  • VerifyModifiedClips (boolean): If true, clip modified/update events for all clips trigger a complete verification (for example treated as the clip was created). If false, only clips currently in the cache are verified. (Default false).
  • CueTimeout (integer): Specifies the maximum time in milliseconds for AV Automation to wait for a cue operation to complete. Default: 1000 msec.
  • PlayTimeout (integer): Specifies the maximum time in milliseconds for AV Automation to wait for a play operation to complete. Default: 0.
  • SetLoopDelay (integer): Specifies the time when to set the clip to play in loop after a successful cue operation, in milliseconds. Default: 1000 msec.
  • NextPingDelay (integer): Specifies the general heartbeat interval. Default: 10000 msec.
  • NextServerAttemptDelay (integer): In case of failure, specifies the time between trying to reconnecting to the video server, in milliseconds. Default: 5000 msec.
  • MirrorActivePortTimeout (integer): For mirroring setups. Specifies the time to wait for the active port to complete before waiting for any of the ports, in milliseconds. Default: 100 msecs.
  • IgnoreCase: If true, searching for clips is done case insensitive. Must be used in combination with <MatchExpression ignoreCase="true" /> from General Search Configuration File Properties.
  • AssetToMediaMap: Choose from two ways of mapping Asset to MediaObject. UseTitleAsSlug or UseMamIdAsSlug.
  • MaxClipNameLength: Naming standard for recordings.
  • ClipNamePattern: When recording a file, the system can be configured to use a predefined pattern for filenames. The pattern shall be defined in the associated config file for the video server. The following variables are available for injecting into the clip name:
    Variable name
    Description
    clipname
    The value given in the recording dialogues, or from custom template commands.
    gallery
    The name of the gallery.
    templateset
    The name of the currently selected templateset.
    timestamp
    The current time. This value can be formatted using the patterns from MSDN.
    Example
    Gallery = MyGallery
    Current template set = MyTemplateSet
    Clipname = MyClipName
    Current Time = 21 September 2016 12:00:00
    Config File for Video Server
    <DeviceConfig xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
    <Properties>
    <item name="ClipNamePattern" value="{gallery}_{templateset}_{clipname}_{timestamp:yymmdd}" />
    </Properties>
    </DeviceConfig>
    The file name sent to recording is MyGallery_MyTemplateSet_MyClipName_160921.
  • HitSortOrder (enum): Specifies how to sort a list of multiple hits for a single search. Used in combination with the BestMatchMethod property. Options:
    • Ascending: The list of hits are sorted ascending alphabetically.
    • Descending: The list of hits are sorted descending alphabetically.
    • Unspecified: (Default) No sorting is applied to the resulting hits.
      Example: <HitSortOrder>Descending</HitSortOrder>
  • BestMatchMethod (enum): Method used to determine single search result if a search results in multiple hits. Options:
    • First: The hits are sorted alphabetically and the first hit is returned.
    • Last: The hits are sorted alphabetically and the last hit is returned.
    • Filter: (Default) Returns the first hit evaluated true from a MatchExpression filter.
  • MatchExpressions (list): List of filters to be used for narrowing searches that may result in multiple hits.
    Each MatchExpression filter is constructed from three attributes:
    • ignoreCase: (boolean) True if the filter is case insensitive. Must be used in combination with property "IgnoreCase" from General Configuration File Properties.
    • expression: (string,regex) Expression used to create a regular expression to be applied to the given clip name. Use the pattern attribute to extract parts of the original clip name to search for. Default: Empty = exact search.
    • pattern: (string) Regular expression used to extract information from the clip name. Default: The original clip name.
      An empty MatchExpressions list results in an exact case sensitive search.
The following example sets up a regular expression filter searching:
MatchExpressions
<MatchExpressions>
<!-- Returns true for all hits with clip names starting with the given clip name -->
<MatchExpression expression="^$1.*$"/>
<!-- Returns true for all hits with identical clip name but case insensitive -->
<MatchExpression ignoreCase=true/>
<!-- Returns true for all hits with clip names containing leading or trailing spaces -->
<MatchExpression pattern = "^\s*(.*)\s*$" expression = "$1"/>
</MatchExpressions>
Device-specific Connection String Parameters
AirSpeed Classic Connection String
Applies to Models
  • AirSpeed
  • AirSpace
  • Type: AirSpeed and AirSpace.
  • Name: Defines the ID of this connection (Default=AirSpeed).
  • Server: Defines the hostname or IP-address of the server.
  • Config: Defines the name of the configuration file.
Optional
  • BasePort*: The lowest port number to connect to (Default=59451).
  • Player*: The player number (1-6). Used for setting the TCP port (Default=1).
  • ChangeCheckInterval: Time in seconds how often to poll AirSpeed for clip changes (Default=1).
  • ReceiveTimeout: Time in seconds to wait for response from AirSpeed (Default=10).
  • HeartbeatInterval: Time in seconds to send out a heartbeat in case of no communication detected from AirSpeed (Default=30).
    Note: The asterisk (*) above denotes the TCP port to connect to becomes BasePort + Player - 1.
Examples
AV Automation:
Name=HAR; Type=AirSpeed; Server=192.168.1.1; Port=6000; Config=ClipServerMultiStream.xml
Media Administrator:
Type=AMS; Name=AirSpace; Server=10.211.114.104; BasePort:59451; Player=2; ChangeCheckInterval=5; ReceiveTimeout=5; HeartbeatInterval=20; Config=ClipServerMultiStream.xml
Configuration file properties can be overridden by connection string properties.
  • KeepCache (boolean): How often (in seconds) to look for clip changes. value=1 is the default value if not configured here (Default=False).
  • RefreshOnUpdate (boolean): When set to true, the cache is updated on each update clip message from the server (Default=True).
  • ReceiveTimeout (integer): Time in seconds to wait for response from AirSpeed (Default=10).
  • ChangeCheckInterval (integer): Time in seconds how often to poll AirSpeed for clip changes (Default=2).
  • HeartbeatInterval (integer): Time in seconds to send out a heartbeat in case of no communication detected from AirSpeed (Default=30).
  • GetMinimumList (boolean): Set to true to retrieve only clip names when initializing database (Default=False).
  • DelayGetClipData (boolean): Delay getting detailed clip information. Information is retrieved for clips in rundown only (Default=True).
  • DelayEventsOnDatabaseInitialization (boolean): If true, all clip handling during database load is postponed until last clip is received (Default=False).
  • SignalDatabaseReady (boolean): Refreshes all clips after database has been built instead of refreshing for every item in the database (Default=True).
  • VerifyModifiedClips (boolean): If true, all modified clip events for clip not in cache are verified, as if they were created (Default=True).
  • ReceiveBufferSize (integer): Set buffer size used for receiving date from AMS. Default 16384 = two times default buffer size of Net.Socket (Default=16384).
  • Encoding (string): Set to encoding used for send/receive from AMS (Default=UTF-8).
  • SupportSearchUsingObjSlug: Ignores search for objSlug if set to false (Default=True).
  • SupportSearchUsingRefID: Ignores search for refID if set to false (Default=False).
Use for debugging purposes only:
  • VerboseLogging (boolean): Set to true to enable logging of received messages from AMS (Default=False).
  • DatabaseCache (boolean): If set to a valid filename, initial load database stores the content in this file (Default=False).
  • DatabaseCacheUpdate (boolean): Determines when the debug database cache is updated (either [Never,Always,Initial]).
  • LoadDatabase: Specifies whether the AirSpeed clip database should be initially loaded and maintained by the Media Administrator. Setting this attribute to true is required if any search should be possible using an AirSpeed video server.
AirSpeed Multi Stream / AirSpeed 5000 Connection String
The AirSpeed Multi Stream driver supports up to six multiple player ports per connection.
Applies to Models
  • AirSpeed Multi Stream 1.8
  • AirSpeed 5000
Optional
  • BasePort*: Specifies the number of the lowest-numbered port on the server. (Default=59451). For AV Automation, six consecutive player ports, starting at this one, are available for playout. (They should be referred to by numbers 1 to 6 in AV Automation.) For Media Administrator, refer to Player and the Note below for how the actual port number is calculated.
  • AV Automation only
    • LoopPostRoll: (only used when NewLooping is true) No. of frames before clip-end to restart loop. Should probably be set to a positive value to obtain smooth looping. Default 4.
    • NewLooping: Whether to use an alternative looping mechanism. Default false. Must be true if MPEG-2 HD clips are involved.
    • OpenSomePlayerAfterConnect: By default, server connection is considered successful ('green') without connecting to any players. If this setting is enabled, also connection to some configured player will be necessary. Default false. Set to true if connection problems are experienced, e.g.
      1. Green server line
      2. Unsuccessful port connect (red port line)
      3. Reconnect
      4. ... and so on ...
    • OpenPlayerAfterConnectTimeout: (only used when OpenSomePlayerAfterConnect is true) Timeout (in milliseconds) for the above OpenSomePlayerAfterConnect functionality (Default=2000).
    • RecordEjectFirst: If true, initiating a recording on a channel/port will first eject any existing clips (Default = False).
    • RecordOverwrite: If true, any recording initiated on an existing clip will delete the existing clip before creating the new (Default=True).
    • RecordUseNameAsClipId: If true, the clip name is also used as clip id when preparing a recording. Otherwise the airspeed will automatically assign clip ids (Default=True).
  • Media Administrator only
    • Player*: Specifies the port to use. Valid values are 1-6. Default=1. See the Note below for how the actual port number is calculated.
Examples
AV Automation:
Name=AMS; Type=AirSpeedMultiStream; Server=192.168.1.1; Config=ClipServerMultiStream.xml
Name=AMS; Type=AirSpeedMultiStreamSearch; Server=192.168.1.1; BasePort:59451; Player=2; ChangeCheckInterval=5; ReceiveTimeout=5; HeartbeatInterval=20; Config=ClipServerMultiStream.xml
With a few exceptions (Type, Name, Config), the connection string properties described above may alternatively be specified in the configuration file. (A connection string setting overrides a corresponding file setting.)
In addition the following properties may be specified in the configuration file:
    • IgnoreCase: Whether clip search is case-insensitive. Default false.
    • NumClips (integer): Number of clips to receive for each server query. Default 50.
    • ReceiveBufferSize (integer): Set buffer size used for receiving date from AMS. Default 16384 = two times default buffer size of Net.Socket (Default= 16384 ).
    • Use for troubleshooting only:
      • DatabaseCacheUpdate : Determines when the debug database cache is updated (either [Never,Always,Initial]).
      • VerboseLogging (boolean): Set to true to enable logging of received messages from AMS (Default=False). Effective only if Verbose logging is turned on in Media Administrator.
    • ReadTimeout: Time in seconds to wait for response from AirSpeed (Default=5).
Amadeus Connection String
Name=HTC-DB; Type=Amadeus; Port=[port]; Config=ClipServerAmadeus.xml
  • Name: Amadeus ID for database
  • Type: Defines the Amadeus driver for clip handling.
  • Port: Set to port to listen for an Amadeus connection.
Optional
  • Port: Defines the connection port (Default=2202).
  • ResponseReadTimeout: Defines the wait time until timeout (default=5000).
  • PollIntervalClips: Defines the time between polling (Default=15). Set to 0 to disable.
  • RundownPrefix: Defines the prefix to add for the rundown name (Default=””).
  • GetAllCGs: If true, METAREQ_ALLCGS message type is used when getting clip info (Default=””). For more details, see the Amadeus documentation.
  • LowerCaseRundowns: If true, then the rundown name is always generated with lower case (Default=False).
  • IgnoreSTEG: If true, all messages from Amadeus starting with STEG are ignored (Default=True). For more details, see the Amadeus documentation.
  • StegCommandIfSubtitled: Sends the specified STEG command if clip is subtitled (Default=KLOCKA INVOKEOFF). For more details, see the Amadeus documentation.
  • SubtitleStegOutOn: Sets the graphics_out_on xml value in the STEG command set to Amadeus (Default=BACKGROUNDEND).
  • PurgeCacheInterval: Use hh:mm:ss format (Default=00:00:00).
  • PurgeCacheAge: Use hh:mm:ss format (Default=00:05:00).
Harris Nexio Connection String
The Harris Nexio driver supports Binary-Coded Decimal TCP/IP transport. The driver can be configured to be case sensitive on searches and use Unicode encoding. The Harris Nexio driver supports recording.
  • Control via RS-422 can be done through VDCP.
  • Maximum five video server units.
  • Type: Harris Nexio
  • Name*: Defines the ID of this connection.
  • Server*: Defines the hostname or IP-address of the server.
Optional
  • Port*: TCP port to connect to (Default=557).
  • Encoding:* Set to “U” or “Unicode” if it should be Unicode.
  • Case*: Set to “B” to be case sensitive on clip name searches.
  • ClipNames:* Property for using exact clip names. If set to “EXACT”, clip names are case-sensitive (Default=EXACT).
  • ChangeCheckInterval: Defines the number of seconds between checks for clip changes.
  • LoadDatabase (boolean):* Set to “true” to build internal database of clips present on server and enable clip monitoring (Default=False).
    Note: The asterisk (*) above denotes the configuration file set property can be overridden by a connection string parameter.
Examples
AV Automation:
Name=HAR; Type=HarrisNexio; Server=192.168.1.1; Port=557; Config=ClipServerHarris.xml
Name=Harris1; Type=HarrisNexio; Server=192.168.1.1; Port=557; LoadDatabase=true; Encoding=UTF-8; ClipNames=UNEXACT; ChangeCheckInterval=15; Config=ClipServerHarris.xml
  • ChangeCheckInterval (integer): Time in seconds how often to poll HarrisNexio for clip changes (Default=5).
  • Port (integer): Defines the default connection port (Default=557).
  • Encoding (string): (Default=ANSI).
  • Case (string): (Default=UPPER).
  • ClipNames (string): Property for using exact clip names. If set to “EXACT”, clip names are case-sensitive (Default=EXACT).
  • KeepCache (boolean): When set to “false”, the cache is cleared on reconnects (Default=False).
  • RefreshOnUpdate (boolean): When set to “true”, the cache is updated on each update clip message from the server (Default=True).
  • VerifyClipDelay (integer): Delay in frames to wait before verifying new clips from server (Default=0).
  • SupportSearchUsingObjSlug: Ignores search for objSlug if set to “false” (Default=True).
  • SupportSearchUsingRefID: Ignores search for refID if set to “false” (Default=False).
  • MaxCueTime (integer): Maximum milliseconds to wait for cue (Default=5000).
  • ClipNamePattern: See General Configuration File Properties.
JupiterWebService Connection String
JupiterWebService is the BBC’s own asset management system.
Name=myServerName; Type=Jupiter; Url=myConfigFile
Example:
Name=Jupiter; Type=Jupiter; Url=ClipServerJupiter.xml
This server type does not support any additional parameters in the connection string. The following settings must be added in the configuration file.
  • Server (string): Defines the hostname or IP-address of the server (Default=localhost).
  • Port (integer): Defines the TCP port to connect to (Default=8102).
  • ServiceName (string): Default=JupiterService.svc.
  • Service (string): Default=http://\{Server}:{Port}/{ServiceName}.
  • GetStatusCommand (string): Default={Service}/clipstatus/{0}.
  • GetKeyFramesCommand (string): Default={Service}/keyframes/{0}.
  • PollIntervalStatus (string): Default={Service}/keyframes/{0}.
MVCP Connection String
MVCP (Multiport Video Computer Protocol) is a simple request/response protocol, which is implemented over a TCP byte-stream connection (for example a stream socket).
Applies to Models
  • Vizrt Xlator
  • SVT F2C file name conversion service
  • Type: MVCP
  • Name: Defines the ID of this connection (Default=MVCP).
  • Server: Defines the hostname or IP-address of the server (Default=localhost).
  • Port: Defines the TCP port to connect to (Default=5250).
  • CustomSearch*: Set to “SVT” to enable SVT custom search on objSlug.
  • SetNameAsRefId*: Set clip name as ref ID in the media object (Default=False) for re-use in other clip servers.
  • WriteTimeOut: Sets the amount of time in milliseconds that a write operation blocks waiting for data from the server (Default=5000).
  • ReadTimeOut: Sets the amount of time in milliseconds that a read operation blocks waiting for data to the server (Default=5000).
  • AppendExtension*: A file extension used when sending messages to the MVCP interface (Default=””).
  • RemoveExtension*: Used to strip the extension of a clip name (Default=””) from the MVCP interface.
    Note: The asterisk (*) above denotes custom search ‘SVT’: SVT has file names with 36 characters. The Nexio only supports 32 characters. SVT exposes a mapping proxy with an MVCP interface and a custom command F2C which translates a long name to a shorter one.
Examples
AV Automation:
Name=MVCP1; Type=MVCP; Server=192.165.4.1; Port=5250
Name=MVCP2; Type=MVCPSearch; Server=192.165.4.1; Port=5251
Omnibus OPUS Connection String
Name=myServerName; Type=OPUS; Url=myUrl; Config=myConfigFile.xml
  • Url: Specifies the URL of the OPUS Interchange web service.
Quantel Connection String
Applies to Models
  • Connects to Quantel using Quantel CORBA interface.
Device Prerequisites
  • Requires Quantel CORBA services to run.
  • Serial numbers of playout servers, normally obtained via Quantel Web interface.
Quantel Video Server Connection String
Name=myServerName; Type=Quantel; Mode=Player; SerialNo=mySerialNo; IOR=myQuantelIOR; Slave=mySlaveAddress; Timeout=10; Config=myConfigFile.xml
  • Name: Specifies a logical name to be associated with the video server. This is used to identify the server across AV Automation and Media Administrator configurations.
  • Type: Specifies which driver to be used for connecting to the server. This should be set to “Quantel” for both AV Automation and Media Administrator.
  • Mode: Specifies whether the Quantel connection is used for playing clips or searching (Default=Search):
    • Mode=Player: The Quantel connection is used for playing clips (AV Automation).
    • Mode=Search: The Quantel connection is used for searching (Media Administrator).
  • SerialNo: Specifies the serial number of the Quantel video server. This number is used to recognize the particular video server within a Quantel zone portal. Serial numbers may be obtained via the Quantel Web interface.
  • IOR: Specifies the Corba IOR used to establish connection with a Quantel server. This IOR is normally obtained from the system administrator.
  • Slave: Specifies an optional slave address. Used when Quantel is configured in a redundancy setup.
  • Timeout: Specifies the timeout in seconds when initially connecting to the Quantel zone portal (ISA manager). Default is 10 seconds.
  • Config: Specifies a configuration file containing custom configuration for the Quantel server driver. Normally set to ClipServerQuantel.xml, which contains the default configuration.
Examples
AV Automation:
Name=sQ7; Type=Quantel; SerialNo=19343; Mode=Player; IOR=http://quantel:@192.168.60.33/ZoneManager.ior; Config=ClipServerQuantel.xml
Name=sQ7; Type=Quantel; SerialNo=19343; Mode=Search; IOR=http://quantel:@192.168.60.33/ZoneManager.ior; Config=ClipServerQuantel.xm
Quantel Configuration File Properties
  • DefaultTakenPortAction (enum): Action when not able to take a port when owned by someone else (Default=Steal). Options:
    • Steal: Takes control over the port even if in use by someone else.
    • Share: Shares control with the other user. Not recommended.
    • Cancel: Cancels the operation. Port is still in control by other user.
  • IssueRequestForTakenPorts (boolean): If true, the user is prompted to confirm taking a port in use by someone else (Default=True). A dialog box appears in AV Automation, warning about taking a port that is currently in use. Only applicable when DefaultTakenPortAction=Steal.
  • ReleasePortsWithNoAssignedChannels (boolean): If true, any unassigned ports (with no assigned channels) are released on player initiation (Default=True).
  • ServerPollFrequency (integer): Polling frequency for server, in seconds.This is used as heartbeat between Viz Mosart and Quantel. Note that heartbeats are not issued if data has been received from Quantel since last heartbeat. (Default=30).
  • ClipNameIsValidNumber (boolean): If true then it is possible to search from Viz Mosart GUI using valid Quantel ClipIDs directly (Default=False).
  • QuantelSlugColumn (string): Specifies the Quantel database column that is used for the clip slug (Default=Title).
  • QuantelClipIDColumn (string): Specifies the Quantel database column that is used for the clip ID (Default=ClipID).
  • QuantelSearchColumn (string): Specifies the Quantel database column that is used for the clip searches (Default=Title).
  • MaxPingAttempts (integer): Maximum ping attempts before a lost connection is detected (Default=1). When Viz Mosart detects a lost connection, the current connection is closed followed by attempts to reconnect. For playout servers only (AV Automation).
  • QuantelRefIDColumn (string): Specifies the Quantel database column that is used for the clip RefID (Default=Title). Used if SupportSearchUsingRefID is set to true.
  • SearchUsingServerIdOnly (boolean): Forces AV Automation to only search for clips using Quantel ClipId’s obtained from Media Administrator if True.
  • ClipNamePattern: see General Configuration File Properties.
Quantel Failure Handling Properties
  • QuantelStatusInterval (integer): Interval in seconds for the Quantel server to send regular status messages. These messages are only sent when the Quantel server is idle. Default: 2 seconds.
  • QuantelCommErrorNumRetries (integer): The number of retries in case of a Quantel CORBA operation results in a CORBA_COMM_FAILURE. Default: 1.
  • QuantelCommErrorTimeout (integer): The timeout in milliseconds between retries in case of a Quantel CORBA operation results in a CORBA_COMM_FAILURE. Default: 100 msec.
Quantel Search Filters
It is possible to define a set of dedicated filters used to either exclude or include hits returned from the Quantel ISA manager. Note that the Quantel ISA manager returns hits for all attached pools. It is necessary to filter out the clips not available on the pools used by the corresponding video servers.
The Quantel search filters are defined in the Quantel configuration file as a list of Filter elements within a SearchFilter element. The following XML structure defines the default filters:
<SearchFilters>
<Filter property="Category" pattern="TEMPORARY CLONE" include="false" />
<Filter property="PoolID" pattern="[PoolID]" include="true" />
<Filter property="IgnoreCase" pattern="true" />
</SearchFilters>
Each filter has the following attributes:
  • property (string): Name of a Quantel database column. A special property=”IgnoreCase” is available to specify case insensitive or case sensitive searches.
  • pattern (string): Regular expression applied on the resulting property.
  • include (boolean): Action to take if the regular expression results in a match:
    • include=false, the hit is excluded from the search.
    • include=true, the hit is returned as part of the search.
      The default example given above shall be interpreted as follows:
  • All clips stored in the Quantel database with Category=”TEMPORARY CLONE” are ignored.
  • Only clips in the Quantel database with a PoolID that matches the pool identity of the corresponding video servers are returned.
  • All searches are case insensitive.
Omneon Connection String
Applies to Models
  • Models with Omneon Spectrum
    Note: Viz Mosart does not work properly with Omneon Spectrum versions earlier than 4.6. In some cases, clip length is not updated when using Omneon Spectrum 6.4.3 or earlier. It is recommended to upgrade to Omneon firmware version 7.9.x or later.
  • Type: Connection type: Omneon or OmneonSearch.
  • Name: ID of this connection.
  • Server: Hostname or IP-address of the server.
  • Player: Performs searches associated with directory for the given player if set. If not set, the Directory option should be used to identify the search directory (optional).
  • Directory: Specifies the search directory (optional).
  • ExtList: File extensions to be used. List of case sensitive extensions separated by periods.
  • ClipDir: Clip directory to monitor for files.
  • LoadDatabase (boolean): Set to true to build internal database of clips present on server and enable clip monitoring (Default=False).
  • Config: Name of the configuration file (ClipServerOmneon.xml).
  • UseFullPath: If true, the Media Administrator returns full clip paths. The clip ID contains both the Omneon server directory, as well as the clip name. Setting this property to true is mandatory if multiple directories are used on a single Omneon server. (Default=False).
Examples
AV Automation:
Type=Omneon; Name=Omneon; Server=10.211.114.104; ExtList=.mov.MOV.mxf.MXF; UseFullPath=true; Config=ClipServerOmneon.xml
Type=OmneonSearch; Name=Omneon; Server=10.211.114.104; Player=Play1; clipdir=/fs0/media; ExtList=.mov.mxf; LoadDatabase=True; Config=ClipServerOmneon.xml
  • KeepCache (boolean): When set to false, the cache is cleared on reconnects (Default=False).
  • DescriptionPattern (string): Makes it possible to extract a description from the object slug (objSlug) based on this Regex pattern (Default=[^_]*_(.*)).
  • DescriptionReplacement (string): Regex expression referring to first matched group (Default=$1). Used when replacing object slug (objSlug).
  • InvokeServerOnGetClipInfo (boolean): If true (non-zero), a request is sent to the video server when doing clip search. If true, all modified clip events for clip not in cache are verified (as if they were created) (Default=False).
  • VerifyModifiedClips (boolean): If true, all modified clip events for clip not in cache are verified (as if they were created) (Default=False).
  • IgnoreCase: If true, searching for clips is done case insensitive. Must be used in combination with <MatchExpression ignoreCase="true" /> from General Search Configuration File Properties .
  • GoToTimeCodeTimeOut (integer): Maximum time to wait (in milliseconds) for successful execution of command to play clip from a given time code (Default=6000).
  • UseNativeGoToTimeCode (boolean): If true, it uses GoToTimeCode method available in Omneon API. This may take a longer time to cue a clip at a specified position (Default=False).
  • UseStopOnCue: If true, the timeline is stopped, not paused (play with speed 0) when cuing a new clip. This causes cuing to take longer than usual.
    Search Properties: See General Search Configuration File Properties.
Grass Valley K2 Connection String
Applies to Models
  • K2
  • Summit
  • Type: GrassValleyK2 (selects the Grass Valley K2 driver for clip handling).
  • Name: See Standard Connection String Properties above.
  • Config: See Standard Connection String Properties above. The installed xml config file is ClipServerGrassValleyK2.xml. Unless changed, the value of Config should be ClipServerGrassValleyK2.xml, cp. the examples below.
  • Bin: The bin of the file repository on the K2 (Default=default).
  • Domain: The domain as part of the user credentials.
  • DontUsePath : (Media Administrator only) For each clip and server, Media Administrator keeps track of the 'id' of that clip on that server. By default (DontUsePath false), that id is the full path and name of the clip on the server. When DontUsePath is true , the id is the clip name only. The default false may be used in most cases. For a Stratus system, changing to true may be considered .
  • FilterGetXmlChanges: (Media Administrator only) If true, only clip changes involving the bin selected by the properties Volume and Bin will be handled. Otherwise (false), all changes are handled. The default false may be used in most cases. For a Stratus system, changing to true may be considered.
  • LoadDatabase: Whether to maintain a 'cache'/'database' of the server clips. Default false. For AV Automation, keep the default false. For Media Administrator, use true.
  • ModificationsInterval : (Media Administrator only; valid o nly when LoadDatabase is true) Interval (in ms) for checking for server change.
  • Pass: The password as part of the user credentials.
  • Server: The IP address/hostname of the Grass Valley K2 server.
  • Suite: The Grass Valley suite. For each K2 server, two, or even three, different Suite values should be used: First, the values for Media Administrator and AV Automation should be different. Second, in a redundancy setup with Main and Backup Mosart server the two values for Media Administrator should be different. (Whereas both Main and Backup AV Automation should use the same value, different from the two Media Administrator values.) And if there is more than one K2 server, this applies to each of them, and all the values should be unique. For further info wrt. the redundancy setup, refer to Failover with K2 Servers.
  • User: The username as part of the user credentials.
  • Volume: The volume of the file repository on the K2. (Default=V:)
Examples
AV Automation:
Name=Summit; Type=GrassValleyK2; Server=K2SERVER1; Config=ClipServerGrassValleyK2.xml; Bin=default; User=GVAdmin; Pass=GVPass; Volume=V:; Suite=GVAdmin; Domain=K2SERVER1
You also need to add the connection string in Mosart Media Administrator. This is the same connection string as in AVAutomation, except that you need to add LoadDatabase=true at the end.
Name=Summit; Type=GrassValleyK2; Server=K2SERVER1; Config=ClipServerGrassValleyK2.xml; Bin=default; User=GVAdmin; Pass=GVPass; Volume=V:; Suite=GVAdmin; Domain=K2SERVER1;LoadDatabase=true;
  • KeepCache: See General Configuration File Properties above.
  • RefreshOnUpdate : See General Configuration File Properties above.
  • VerifyClipDelay : See General Configuration File Properties above.
  • VerifyModifiedClips : See General Configuration File Properties above.
  • BypassRetrieveServerConfig (Boolean, default false): (AV Automation only) Whether to bypass retrieval of channel configuration from the server. Set to true if there are problems connection to one or more channels (red line).
  • CloseChannels (Boolean, default true): (AV Automation only) Whether channels are closed at disconnect. Use false in a redundancy setup with Main and Backup Mosart servers to prevent clip ejection on failover. Otherwise, use true. (See Failover with K2 Servers below.)
  • MaxCueRetries: Maximum number of cue/load attempts. Default 1.
  • RecordingBin (string): (AV Automation only) The server bin where clips are to be recorded. (This bin must be in the volume specified by RecordingVolume.) Both RecordingBin and RecordingVolume must be specified if clips are to be recorded in a specific bin. If neither is specified, the recording location is undefined.
  • RecordingVolume (string): (AV Automation only) The server volume where clips are to be recorded. Both RecordingBin and RecordingVolume must be specified if clips are to be recorded in a specific bin. If neither is specified, the recording location is undefined.
  • SuspendConnection (Boolean, default false): (AV Automation only) See Failover with K2 Servers below. Use true in a redundancy setup with Main and Backup Mosart servers to prevent clip ejection on failover. Otherwise, use false.
  • UseExtendedLogging (Boolean, default false): Adds some more logging. Valid only if Verbose logging is turned on. Should normally be kept at the default false.
  • UseMovieAddedNotice (Boolean, default false): Whether to utilize the MovieAddedNotice element when processing a MovieAdded notice.
    Note: This setting was introduced to handle added clips at an installation with rather old GV firmware. In the default ClipServerGrassValleyK2.xml, this setting is true. (But if the setting is removed altogether, the actual default value is false .) Change to false (or remove setting) if added clips are not handled correctly (e.g., if a clip added on the GV server does not turn solid blue in GUI.)
  • UseVideoFormatFromServer (Boolean, default true): Set to false if clip durations (e.g. as shown in GUI) are incorrect.
When GVG K2 servers are connected to both main and backup Mosart servers, any cued or playing clips would be ejected from the K2 ports during failover.
This is not desirable, so a further layer of configuration file properties have been provided for avoiding this:
  • CloseChannels, default true
  • SuspendConnection, default false.
For a redundancy setup with Main and Backup Mosart servers, use instead these settings:
<item name="CloseChannels" value="false" />
<item name="SuspendConnection" value="true" />
With these settings, the outgoing Mosart server (e.g. main) will disconnect in a way that allows the incoming Mosart server (e.g. backup) to retake the same connections and channels.
This ensures that no clips are ejected in the process.
The prerequisite for this to work is that the Connection String Properties on main and backup are set up with identical Suite names (for AV Automation).
Stratus
The two connection string properties
  • DontUsePath
were introduced at installations with a Stratus system to ensure that deleted clips appeared chequered in the Mosart GUI.
The default value of both settings is false, and that has, as far as we know, worked for all other installations. We recommend the following:
  1. Start using the default value false for both settings.
  2. If problems of the type indicated (deleted clips stay solid blue in GUI) are encountered, change both settings to true.
Other combinations (than both false and both true) have not been tested.
EVS LinX Connection String
This connection string is used for EVS video servers controlled by the LinX protocol (as opposed to EVS Xedio systems, see EVS Xedio Connection String).
Type=EVS LinX; Name=[name]; Server=[IPaddress]; LoadDatabase=true; Config=ClipServerEvsLinX.xml
Example
Type=EVS LinX; Name=EvsLinXName; Server=192.168.62.6; LoadDatabase=true; Config=ClipServerEvsLinX.xml
  • Type: EVS LinX or EVS.
  • Name: Defines a unique name for the server.
  • Server: Defines the IP address of the server.
  • LoadDatabase: If true, loads all clip metadata into local cache (Default=False). Use true for Media Administrator.
  • Config: Configuration file containing further configuration settings.
Optional
  • LogOutput: The LinX log file created for the LogFlag option 0x00000003. The files for the other options are in the same folder, and with names derived from LogOutput (see LogFlag below for details.) The folder should exist in advance, and the Viz Mosart user should have permission to create and write files. AV Automation and Media Administrator should log to different files, so LogOutput should be specified (with different folders) in the respective connection strings rather than in this file.
  • VeryVerbose: If true (and the Viz Mosart application issues verbose logging), then some extra log messages are issued (Default=False).
Config File Parameters
  • SupportSearchUsingObjSlug: Search by ‘slug’ (clip name) is supported (Default=True).
  • SupportSearchUsingRefID: Search by a configurable clip property (given by the SearchPropertyName parameter; see below) is supported (Default=False).
  • HeartbeatTimeout: The time (in milliseconds) after which the server connection may close if there is no activity (Default=12000).
  • KeepAliveIntervalDivisor: In case of connection problems, multiply both HeartbeatTimeout and KeepAliveIntervalDivisor by the same factor (for example, two) (Default=8).
  • LocalMtpcIpAddress: Necessary only if the Viz Mosart server has several network adapters, e.g. a virtual adapter (or several virtual adapters) in addition to the physical adapter, e.g. when VMWare (or similar) is installed on a demo PC, or when connecting through VPN. In this case, use the IP address (in the usual format of four dot(.)-separated groups of one to three decimal digits) of the network adapter connected to the EVS servers.
  • LogFlag: Bitmask specifying LinX log level. Available options are listed in the table below. (In addition, linxFunctions.log is produced.) The options may be combined. For example, 0xFFFFFFFF produces all log files.
    Bitmask
    Description
    Log file, given LogOutput=...\linx.log
    0x00000003
    Function entry and exit points, with parameters and return code
    linx.log
    0x00000010
    Connections
    linxConnect.log
    0x00000400
    Databases
    linx_Archive.log
    0x00008000
    Debug
    linxDebug.log
    0x01000000
    Tools
    linxTool.log
  • MaxTries: Obsolete. Instead, use SharedNbMaxConnectRetry and SharedConnectTimeout, described below. (The maximum number of times to try to synchronize the database. Default=10).
  • NbMaxLinxConnection: The maximum number of connections. The default is 18, to accommodate two EVS servers. Add 9 for each additional server.
  • OsdDefine00 - OsdDefine11: Defines the 12 OSD lines.
  • OsdShowHideError: Defines whether or not to show OSD.
  • OsdShowHideErrorSignals: Defines whether or not to show OSD. (For further details of these and other OSD settings, please see the default configuration file.)
  • SearchPropertyName: Clip property that may be used for clip search. The default is Varid (a LinX specific clip ID that may be used to identify clips in the NRCS). If some other property is needed, please ask Viz Mosart personnel for a list of available values.
  • SharedNbMaxConnectRetry: Maximum number of retries in case of connect error on a shared connection (Default=16). Increase if the error code 'Too many retries' is encountered, e.g. when synchronizing the database.
  • SharedConnectTimeout: Maximum time in milliseconds to execute connection request on a shared connection (Default=500). Consider increasing if the error code 'Too many retries' is encountered, e.g. when synchronizing the database.
Applies to Models
  • XS family (6U, 4U)
  • XT family (XT2+, XT3, not nano)
  • Multicam 10.03, or later
  • LinX license code
  • Channels to be controlled by Viz Mosart must have Main CTRL LinX.
  • The network, including any firewalls, connecting the Viz Mosart server(s) and the EVS server(s) must support and allow TCP (ports 50000-50002) and UDP (unicast and multicast, ports 50100-50108).
These connection strings are used for EVS Xedio video servers (as opposed to EVS video servers controlled by the LinX protocol, see EVS LinX Connection String).
From a Viz Mosart perspective, a Xedio system has three parts:
  • One or more playout servers.
  • A control center.
  • A DB connected to through ODBC.
AV Automation controls the playout servers, whereas Media Administrator connects to the control center and the database. Consequently, the connection strings for AV Automation and Media Administrator are somewhat different.
AV Automation Connection String
Type=EvsXedio; Name=[name]; Config=ClipServerEvsXedio.xml
Example:
Type=EvsXedio; Name=EvsXedioName; Config=ClipServerEvsXedio.xml
AV Automation Connection String Parameters
  • Type: EvsXedio.
  • Name: Defines the unique name for the server.
  • Config: Defines the configuration file containing further details.
Note: The parameters mentioned so far are insufficient to connect to a playout server. The IP address and port number are also required.
These are specified (separated with : ) in the Video port field(s) in AV Automation Device Properties, for example 192.168.76.11:4021.
Media Administrator Connection String
Type=EvsXedioSearch; Name=[name]; Server=[IPaddress]; Config=ClipServerEvsXedio.xml
Example:
Type=EvsXedioSearch; Name=EvsXedioSearchName; Server=192.168.76.10; Config=ClipServerEvsXedio.xml
Media Administrator Connection String Parameters
  • Type: EvsXedioSearch.
  • Server: Defines the IP address for the Control center.
Note that the parameters mentioned so far are insufficient to connect to the database. For this, the parameters DataSourceName, User, and Password are required. The defaults are probably sufficient. If not, these parameters are more conveniently set in the configuration file, described below.
Configuration File Parameters
  • PrefixTypeEdit: MOS objIDs with this prefix are treated as 'edits' (Default=EVSE).
  • PrefixTypeMedia: MOS objIDs with this prefix are treated as 'media' (Default=EVSM).
Relevant for AV Automation Only
  • TimeOut: Defines the timeout in milliseconds (Default=1).
Relevant for Media Administrator Only
  • AcceptHighResolutionOnly: Whether only high resolution clips are accepted (Default=False).
  • DataSourceName: ODBC System DSN entry for the CleanEdit DB (Default=CleanEditDB).
  • MonitorClipInterval: The interval (in seconds) at which found clips are monitored (Default=60). Used only if MonitorFoundClips is true, see below.
  • MonitorFoundClips: Whether found clips are monitored (Default=False).
  • Password: Password for the CleanEdit DB.
  • PrefixCheckItemReturnAllItemHiResPresent: The prefix added to the Description of a hi-res clip (Default=HIRES-).
  • PrefixCheckItemReturnError: The prefix added to the Description of an error clip (Default=ERROR-).
  • PrefixCheckItemReturnNotPlayable: The prefix added to the Description of non-playable clip (Default=NOTPLAYABLE-).
  • PrefixCheckItemReturnOnlyItemLowResPresent: The prefix added to the Description of a lo-res clip (Default=LORES-).
  • SkipGetDuration: Whether to skip getting clip duration. Note that this operation may be slow and MAY be rendered unnecessary by future Media Administrator dev (Default=False).
  • User: User for the CleanEdit DB.
Debug Parameters, Relevant for Media Administrator Only
  • LogFile: CleanEditOcx log file (Default=C:\EvsLogs\CleanEditOcx\CleanEditOcx.log).
ScreenLL Connection String
Screen Connection String, used by Media Administrator.
Name=myServerName; Type=ScreenLLSearch; Server=myMainServerLocator;BackupServer=myBackupServerLocator; ServerUsage=myServerUsageMode; Config=myConfigFile.xml
  • Name: Not important, used for logging purposes only.
  • Type=ScreenLL: Defines the Screen Lingua Lib search driver for clip handling.
  • Server=path: Defines where subtitle clips are located on the main subtitle server.
  • BackupServer=path: Defines where subtitle clips are located on the backup subtitle server, if applicable.
  • ServerUsage=mode: Specifies how availability status is updated based on (main) server and backup server clip status:
    • 0: available if clip is present on main server.
    • 1: available if clip is present on backup server.
    • 2: available if clip is present on either main or backup server.
    • 3: available if clip is present on both main and backup server.
  • Config=ClipServerScreenLL.xml
Orad Using OCIP Connection String
This connection string is used for Orad video servers controlled by OCIP (Orad Control Interface Protocol).
Type=Orad OCIP; Name=[Name]; Server=[hostname/IP address]; Port=[Port]; LoadDatabase=true; Config=ClipServerOradOcip.xml
Example
Type=Orad OCIP; Name=OradVJ; Server=192.168.15.1; Port=10001; LoadDatabase=true; Config=ClipServerOradOcip.xml
  • Type: Orad OCIP.
  • Server: Defines the server hostname.
  • Name : See Standard Connection String Properties above.
  • Port: Defines the server port. By default, the four ports 10001 , 10002 , 10003 , and 10004 are configured on an OCIP-controlled Orad server. We recommend using different ports for AV Automation and Media Administrator.
    Example: 10002 for AV Automation and 10003 for Media Administrator.
  • LoadDatabase: If true, the server database is loaded at start-up (Default=False). Use true for Media Administrator.
  • AllowSetPosition: Whether to enable 'scrubbing'/'scrolling' the in-point of a cued clip in the GUI. Default: False. Effective only for servers supporting OCIP 3.0.0 or higher. (Only tested with OCIP 4.0.0.)
  • CopyObjSlug: Whether the value of the clip 'slug' (the slug is the value of the OCIP item parameter set in ObjSlugParameter) shall be copied 'upwards' (to MediaAdmin).
    Default: False.
    The value for CopyObjSlug in the installed ClipServerOradOcip.xml file, is initially set to True. This will be the value for new installations.
    If problems are experienced when a clip is first deleted and then re-created with the same SourceId (assuming that is the value of the ObjSlugParameter setting), but a different Id, make sure this setting is True.
  • IgnoreGrowingItems: Whether clips with growing parameter set to True will be ignored.
    When set, this implies that growing clips are processed as non-existent and are unavailable.
    Default False. Available for Avid FastServe running FSP 2018.8 or higher. The RequestGrowing setting must be True for this to have effect.
  • LoopPostRoll: Number of frames before clip-end to restart loop. Set to a positive value to obtain smooth looping.
  • ObjSlugParameter: The OCIP item parameter to use for clip 'slug'. The values of this parameter should match the values of the 'clip_hirespath' newsroom tag.
    Default 'Name'. This default value has worked for the video server Orad VJ. Other workflows, especially using Avid FastServe, require using the value 'SourceId'. Other values are not verified as supported.
  • RequestGrowing: Whether to request the Growing parameter from the server. Default False.
    Set to True if the IgnoreGrowingItems feature is to be used.
  • SetInAndOutPoint: How a clip's in-point and out-point are set. Available values:
    • FromServer: (Default) From the item's In and Out parameters. This may yield incorrect results if the In parameter is different from 0.
    • ZeroAndDuration: (Value in the installed ClipServerOradOcip.xml file, so this will be the value for new installations.) As 0 and the item's Duration parameter.
    • Dont: For future/internal Vizrt Support use. Do not use this value.
  • SkipAbortInLoadClip: If true, skip the ChannelAbort command at cue (Default=False).
  • TimeoutDefault: Timeout in milliseconds for commands with no specific timeout set (Default=1000 which is 1 second).
  • TimeoutChannelAbort: Timeout in milliseconds for the ChannelAbort command performed at cue.
  • TimeoutChannelJog: Timeout in milliseconds for the Jog command performed at 'scrubbing'/'scrolling'. (See AllowSetPosition).
  • TimeoutChannelPause: Timeout in milliseconds for the ChannelPause command.
  • TimeoutChannelPlay: Timeout in milliseconds for the ChannelPlay command performed at cue.
  • TimeoutChannelPlayInit: Timeout in milliseconds for the ChannelPlayInit command performed at cue (Default=4000 (4 seconds)).
  • TimeoutChannelSetSpeed: Timeout in milliseconds for the ChannelSetSpeed command performed at play.
  • TimeoutChannelStatus: Timeout in milliseconds for the ChannelStatus command.
  • TimeoutCreateCallbackItem: Timeout in milliseconds for the CreateCallbackItem command at start-up (Default=2000 (2 seconds)).
  • TimeoutItemCheck: Timeout in milliseconds for the ItemCheck command occasionally performed at cue.
  • TimeoutItemGet: Timeout in milliseconds for the ItemGet command occasionally performed at cue, and also for getting status.
  • TimeoutListChannel: Timeout in milliseconds for the ListChannel command at start-up.
  • TimeoutListItem: Timeout in milliseconds for the ListItem command at start-up (Default=2000 (2 seconds)).
  • UpdateInAndOutPoint: Whether clip in-point and out-point should be copied 'upwards' (to MediaAdmin) for clips with growing duration.
    Default: False. Change to True if such clips are not shown with correct duration in GUI.
  • UseHashKey: If True, the item Id will be used as clip 'id'. If False, clip 'slug' will be used. (See settings ObjSlugParameter and CopyObjSlug above.)
    Default: False. However, the value in the installed ClipServerOradOcip.xml file is True, so this will be the value for new installations.
  • UsePingOcipOperation (boolean): If true, use an OCIP operation for Ping instead of the default TcpIpClient ping (Default=False).
Debug Parameters
  • KeepSpeed: For Vizrt Support use. Default: False.
    Do not change!
  • WSACancelBlockingCallExceptionTraceEventType: The TraceEventType for the WSACancelBlockingCall exception.
    Options: Critical, Error, Warning, Information, Verbose (Default=Error).
Applies to Models
  • Orad VJ
  • Avid FastServe
  • OCIP 1.0.4. Some features require OCIP 3.0.0.
  • Avid FastServe. Some features require FSP 2018.8.
VDCP Connection String
The VDCP driver supports both serial and TCP as transport. Video Disk Communications Protocol (VDCP) is also known as Louth protocol. The driver can be configured to run in eight character or variable character mode.
Applies to Models
  • Dalet BRIO
  • Vector MultiPlay VServer
Device Prerequisites - VDCP
  • Dalet BRIO
    • Single VDCP connection configuration per port - does not support multiple control ports per connection.
    • Only clips in folders added to the BRIO VDCP configuration are visible for Viz Mosart to monitor and play-out.
    • Duration of video files is only available if the VDCP connection is configured to use a physical play-out port.
Connection String Properties - VDCP
  • Type: VDCP (serial) or VDCPtcp (Ethernet).
  • Server: Hostname or IP-address of the server (for Type=VDCPtcp only).
  • Port: Serial port (Type=VDCP, Default=COM1) or server side TCP port to connect to (Type=VDCPtcp, Default=52z05).
  • LoadDatabase: If true, builds internal database of clips present on server and enables clip monitoring (Default=False).
  • Config: Name of the configuration file. ClipServerVDCP.xml is the default name of the file used by VDCP Connection String.
Examples
AV Automation: VDCP (serial)
Type=VDCP; Name=Server1; Port=COM1; Config=ClipServerVDCP.xml
AV Automation: VDCPtcp (Ethernet)
Type=VDCPtcp; Name=Server1; Server=192.168.42.42; Port=10001; Config=ClipServerVDCP.xml
Media Administrator: VDCP (serial)
Type=VDCP; Name=Server1; Port=COM2; LoadDatabase=true; Config=ClipServerVDCP.xml
Media Administrator: VDCPtcp (Ethernet)
Type=VDCPtcp; Name=Server1; Server=192.168.42.42; Port=10002; LoadDatabase=true; Config=ClipServerVDCP.xml
Configuration File Properties - VDCP
  • DefaultRecordingLength (integer): Default duration of recorded video files in frames (Default=1000).
  • DelayGetClipDuration (boolean): Enable to build the initial playlist without getting the file duration (Default=False).
  • IgnoreClipExistence (boolean): Enable to ignore requesting clip presence on the server.
  • LogMessages (boolean): If true, log any messages that are sent and received. Verbose logging must be activated for this to have effect (Default=False).
  • MaxClipList (integer): The maximum amount of clips to hold in cache. When this limit is reached, there are no more clips added to the cache. Setting this to a low value reduces load time, but might cause invalid clip status if non-cached clips are in the rundown.
  • UseInternalPlayerState (boolean): Enable to ignore requesting presence of the clip on the play-out device using the ID REQUEST message.
  • UseLongClipNames (boolean): If true, use messages supporting variable length file names (maximum length 80 characters). If false, use fixed eight character files names padded with spaces if less than eight characters.
  • UseAddedClipsCommand (boolean): Enable to retrieve a list of new files added to the video server.
  • NextPingDelay (miliseconds): Interval in milliseconds between heartbeats sent from AV Automation to the VDCP server to keep the connection alive. Default = 10 seconds). e.g.: <item name="NextPingDelay" value="10000" />
    Turn off this ping using the DisableHeartbeat setting described below.
    To modify the ping interval for Media Administrator see Media Administrator Properties Editor > Ping Delay.
  • DisableHeartbeat (boolean): A command request (heartbeat) is sent from AV Automation and Media Administrator to the VDCP server to keep the connection alive.
    • Turn off the heartbeats from both AV Automation AND Media Administrator by setting DisableHeartbeat=true in ClipServerVDCP.xml. e.g. <item name="DisableHeartbeat" value="true" />
    • Turn off the heartbeats from one application (AV Automation OR Media Administrator), by setting DisableHeartbeat in the application’s connection string and removing (commenting out) DisableHeartbeat from ClipServerVDCP.xml.
      Example connection string: Type=VDCPtcp;Name=Server1;Port=10001;DisableHeartbeat=true;Config=ClipServerVDCP.xml
      See also NextPingDelay, described above.
Viz Engine Connection String
Viz Engine Connection String, used by Media Administrator and AV Automation.
  • Type: VizEngine.
  • Name: Defines the ID of this connection.
  • Server: Defines the hostname or IP-address of the server (for Type=VizEngine only).
  • Port: Defines the port.
  • Folder: Location of the Viz Mosart configuration files. Either in %ProgramFiles(x86)%\Mosart Medialab\Mosart Server\ConfigurationFiles or with the video configurations in C:\channeltemplates.
Examples
Connection string for Integrated Engine (Viz Engine connection in AV Automation):
Type=VizEngine;Server=localhost;Config=VizEngineSwitcherConfig.xml (Port=6100 is optional)
Connection string for Video Server (Viz Engine connection in AV Automation):
Name=Vizrt;Type=VizEngine;Server=localhost;Port=6100;Config= ClipServerVizEngine.xml
Connection string for Media Administrator:
Name=VizEngine;Type=SimpleTestPlayer;Folder=D:\;SkipExtension=true;Config=ClipServerVizEngine.xml
  • AlwaysGetDuration (default=FALSE):
    • When FALSE, only files in the active Viz Mosart rundown get the actual video duration.
    • When TRUE, get the video duration from all files in the monitored folder. Note that setting this value to true impacts the startup time of the SimpleTestPlayer driver in Media Administrator for folders with a large number of video files.
Viz One and Media Service Connection String
This connection string is used by Viz One and Media Administrator for Media Service.
Viz Mosart can search for clips in Viz One and initiate transfer of Viz One clips to a specified playout storage. The driver uses the REST-based Viz One Third party API to execute tasks.
Device Prerequisites (Viz One)
For further details, please consult the Viz One Administrator Guide.
  • At least one Viz One user at least one publishing point must be configured.
Naming
Examples
Description
Name
VizOne
VizEngine
MediaSearch
Name of connection. Should be equal the name of the video server in AV Automation.
Type
VizOne
Type of connection. Must be VizOne to use the Viz One Clip Administrators.
UserName
vizmse
Viz One only
Username for user that connects to third party API.
Please look at separate section in this document on how to create a dedicated user for Viz Mosart to access Viz One.
admin as username and password may be used for testing, but should not be set in production.
Password
vizmse
Viz One only
Password for user that connects to third party API
Server
10.211.112.213
bgoqavizone
IP address or host name of Viz One server
PublishingPoints
vve2-1
vizengine-1
MediaService
A publishing point is a playout storage defined in Viz One. This can be accessed through Administration menu on the Web interface.
Comma separated list of publishing point identifiers where the clip administrator should ensure assets are present.
If “MediaService” is specified for PublishingPoints, Media Service and not Viz One is used to search for clips.
ValidDuration
26
Viz One only
Duration for which an asset should be present on the publishing point from time of transfer. Value is in hours.
Default: 24
AutoTransfer
true
false
Viz One only
true: Any assets in the playlist that is present in Viz One, but not on the publishing points will be transferred.
false: Assets are marked as not present.
True is default value.
PublishingPointAsObjId
true
false
true: An ObjectId will be set for each publishing point as well as Name from connection string (an additional server ID is set for each publishing point).
false: Use Name from connection string as ObjId (only one server ID is set: for Name).
False is default and most common.
Port
21099
Media Service only
MediaService requires port to be specified.
Default port is 21099 for MediaService.
See also Configure Media Service section in the Media Service guide.
(Viz One does not require this field).
Config
ClipServerVizOne.xml
Name of configuration file located in ChannelTemplates folder.
See also Standard Video Server Connection String.
Example (Media Service)
Name=VizEngine;Type=VizOne;Server=localhost;Port=21099;PublishingPoints=MEDIASERVICE;Config=ClipServerVizOne.xml
Example (Viz One)
Name=VizOne;Type=VizOne;UserName=username;Password=password;Server=10.211.112.213;PublishingPoints=vizengine-1;ValidDuration=26;AutoTransfer=true;PublishingPointAsObjId=false;Config=ClipServerVizOne.xml
Note: The differences between ClipServerVizEngine.xml and ClipServerVizOne.xml is that the first one handles video server in configuration AvAutomation and second is only for establishing clip searches in Media Administrator.
SQL Database Connection String
This connection string (in Media Administrator) is for the SqlMediaSearch driver, for reading clip metadata from an RDBMS (Relational DataBase Management System) using SQL, and then computing clip properties based on:
  • SQL query results.
  • Existing clip properties (referred to as properties of 'the clip sent down to the SqlMediaSearch driver').
It is assumed that
  • All metadata resides in a single database table (the clip table).
  • The metadata of a single clip is found in a single row (the clip row) in this table.
The driver is designed to be used in conjunction with one or more video servers, to provide additional metadata about clips residing on the server(s). The presence of clip metadata in the database is not considered proof of clip existence; Only clips that exist on a video server appear as blue in the viz Mosart GUI.
Place this connection string above (e.g. in Video clip Server 1) that/those of the video server(s).
Applies to Models
The driver has been designed to interact with any RDBMS (Relational DataBase Management System) using SQL. However, it has only been verified with following versions of Microsoft SQL Server:
  • Microsoft SQL Server 2012 (SP1) - 11.0.3000.0 (X64)
  • Microsoft SQL Server Express (64-bit) - 11.0.2218.0
Create a DB user with:
  • Read access to the table containing clip data.
  • No write or admin access. (As no attempts to prevent SQL injection have been done, this is necessary to prevent unauthorized changes to the DB).
General Format
Name=DB;Type=SqlMediaSearch;ProviderName=System.Data.SqlClient;Config=ClipServerSql.xml;DbConnectionString="..."
  • Name: See Viz Mosart Video Server Connection String above.
  • Type: SqlMediaSearch.
  • Config: See Viz Mosart Video Server Connection String above. A configuration file ClipServerSql.xml is installed. Use the name of this file (ClipServerSql.xml unless changed).
  • ProviderName: The 'invariant name' of a .NET Framework data provider. At least the following providers are installed with the .NET Framework:
    • System.Data.SqlClient
    • System.Data.Odbc
    • System.Data.OleDb
    • System.Data.OracleClient.
Others may have been installed. Only System.Data.SqlClient has been verified.
  • DbConnectionString: The connection string (containing connection settings) sent to the chosen provider. The format depends on the chosen ProviderName. For System.Data.SqlClient (the only verified provider) the format is documented in https://msdn.microsoft.com/en-us/library/system.data.sqlclient.sqlconnection.connectionstring(v=vs.110).aspx. Quotes in the value have not been tested and may not work as expected.
  • FileClipProperties: Same as the ClipServerSql.xml parameter. As this is set in ClipServerSql.xml, see below.
  • FileSelectStatements: Same as the ClipServerSql.xml parameter. As this is set in ClipServerSql.xml, see below.
  • LogResult: Same as the ClipServerSql.xml parameter. As this is set in ClipServerSql.xml, see below.
  • DefaultTableName: Same as the ClipServerSql.xml parameter. As this is set in ClipServerSql.xml, see below.
  • MonitorFoundClips: Same as the ClipServerSql.xml parameter. As this is set in ClipServerSql.xml, see below.
  • MonitorClipInterval: Same as the ClipServerSql.xml parameter. As this is set in ClipServerSql.xml, see below.
Example
Name=DB;Type=SqlMediaSearch;ProviderName=System.Data.SqlClient;Config=ClipServerSql.xml;DbConnectionString="Persist Security Info=True;Initial Catalog=HarrisDBTest;Data Source=BGO-OFRENGINE\SQLEXPRESS;Failover Partner=aut-db-srv03.fs-pn.vizrtnet.int\harris;User ID=test;Password=test;"
Configuration Files
There are three configuration files:
When the Mosart Server is installed, these files are placed in the ConfigurationFiles sub-folder of the installation folder. If any file shall be be changed, follow the standard procedure:
  • Copy the file to c:\channeltemplates, and change the copy .
    If you choose to change the name, you must also change (accordingly):
    • If the name of ClipServerSql.xml is changed: The Config connection string parameter.
    • If the name of SelectStatements.xml is changed: The FileSelectStatements parameter in ClipServerSql.xml (below).
    • If the name of ClipProperties.xml is changed: The FileClipProperties parameter in ClipServerSql.xml (below).
ClipServerSql.xml
This is the main configuration file for the driver. These configuration parameters are available:
  • FileClipProperties: The name of the file containing clip properties to be pulled from DB. Default ClipProperties.xml, as described below.
  • FileSelectStatements: The name of the file containing the SELECT statements to be used. Default SelectStatements.xml, as described below.
  • LogResult: Whether query results should be logged (in Media Administrator console and in Viz Mosart log). Default true. Set to false if everything works fine, and the messages are superfluous.
  • DefaultTableName: The name of the outer XML element shown when using LogResult. The default (dummy) is usually OK.
  • MonitorFoundClips: Whether found clips should be monitored. Default true. If set to false, missing or changed clips are not detected.
  • MonitorClipInterval: If the value is X (and if MonitorFoundClips is true), each found clip is re-queried every X seconds. Increase if DB traffic is too high.
  • DbConnectionString: Same as the connection string parameter; As this is set in the connection string paramters, see above.
  • ProviderName: Same as the connection string parameter; see above. Should be set in the connection string.
In addition, these 'common'/'standard' parameters are available:
If the name of this file is changed, the configuration parameter FileSelectStatements in ClipServerSql.xml must be changed accordingly.
To further understand this configuration, please study the examples provided in the installed file.
This file defines the SQL SELECT statements that are executed when:
  • The DB is queried for data on a single clip.
  • The DB is searched for clips satisfying a given search criterion.
Each of these two SQL SELECT statements is defined by a SelectStatement element. For technical reasons, the two SelectStatement elements are enclosed in a Statements element, which in turn is enclosed in a SelectStatements element.
A SelectStatement element has these attributes:
Attribute
Value(s)
Description
type
Single/Multiple
Distinguishing between the two types of SQL SELECT statements.
database
The DB name.
schema
The schema name.
table
The table name.
A SelectStatement element has these sub-elements:
Sub-element
Description
SelectColumns
The columns in the SELECT clause of the SQL statement.
WhereColumn
The WHERE clause column to be searched for the (variable) search criterion.
AdditionalWhereColumns
Additional WHERE clause columns being searched for constant values.
The SelectColumns element has one or more SelectColumn sub-elements, each with these attributes (and no sub-elements):
Attribute
Value(s)
Description
name
The DB column name
type
String/Int
The DB column data type. For Microsoft SQL Server,
  • String is used for char and varchar columns.
  • Int is used for int columns.
format
Default/HhMmSsFfPackedBCD
How a column value is to be interpreted:
  • Default: The value is passed as is. (And this is default, so it is used if no format attribute is present.)
  • HhMmSsFfPackedBCD: The (four-byte) int value is interpreted as the packed BCD representation of a time code hh:mm:ss:ff. This is converted to the total number of frames. E.g., the int (decimal) 404310278 is hex 18194906, corresponding to the time code 18:19:49:06, in total 1649731 frames.
The AdditionalWhereColumns element has one or more WhereColumn sub-elements.
A WhereColumn element (either as a direct sub-element of SelectStatement, or as a sub-element of AdditionalWhereColumns) has these attributes:
Attribute
Value(s)
Description
Comment
name
The DB column name
type
String/Int
Only String has been tested.
value
The value to search for
Used only for WhereColumn elements which are sub-elements of AdditionalWhereColumns.
For the WhereColumn sub-element of SelectStatement, the value to search for is given by context.
searchMethod
BeginsWith/IsEqualTo/EndsWith/Contains
How the column value ( c ) is compared to the value to search for ( s ):
  • IsEqualTo: c must be exactly equal to s
  • BeginsWith: c must begin with s
  • EndsWith: c must end with s
  • Contains: c must contain s
Only IsEqualTo makes sense for Int.
EndsWith and Contains have not been tested.
IsEqualTo has not been tested for Int.
ClipProperties.xml
If the name of this file is changed, the configuration parameter FileClipProperties in ClipServerSql.xml must be changed accordingly.
This file defines the clip properties computed by the driver. Each of these properties is defined by a Property element. For technical reasons, the Property elements are enclosed in a Properties element, which in turn is enclosed in a ClipProperties element.
A Property element has one attribute:
Attribute
Description
Comment
name
The property name
Only these have been implemented:
  • Description (the clip description as shown in the GUI (if selected by the setting Video clips should be presented with there))
  • InPoint (the clip in point as shown in the GUI Preview window)
  • ObjSlug (the clip slug as shown in the GUI Media pool Search tab)
  • OutPoint (the clip out point as shown in the GUI Preview window)
A Property element has one sub-element, an expression. The principal feature of an expression is that it may be evaluated to yield a value. There are four kinds of expression elements (so a Property element has one of these as a sub-element):
Sub-element
Description
Comment
ClipExpression
The value of a ClipExpression depends only on a property of the clip as sent down to the SqlMediaSearch driver.
The clip properties available depend on the video server driver(s) used together with SqlMediaSearch. Only the BasePoint property (start timecode in frames, available for the HarrisNexio driver) has been tested.
DbExpression
The value of a DbExpression depends only on the value of a column in the clip row (the DB row pertaining to the clip).
The column has to be defined by a SelectColumn element as described in the SelectStatements.xml section above.
ConstantExpression
The value of a ConstantExpression is (as strongly indicated by the name) constant , it depends neither on the clip as sent down to the SqlMediaSearch driver, nor on the DB.
ConstantExpressions were introduced for internal purposes, and have not been real-life tested.
OperationExpression
An OperationExpression is used to combine other (simpler) expressions by performing an operation, which means applying an operator to the values of its operands (sub-expressions). Each operand/sub-expression may be of any of the four kinds of expression listed in this table. In particular, OperationExpressions may be nested to any depth.
A ConstantExpression element has one attribute:
Attribute
Description
value
The (constant) value of the ConstantExpression
Both a ClipExpression and a DbExpression has two attributes:
Attribute
Description
name
See table below
default
The value to be used if evaluating the expression as described in the table below doesn’t make sense in the given context
The name attribute and expression evaluation is described in more detail for each of the two kinds of expressions:
Expression kind
Description of the name attribute
Expression value
Comment
ClipExpression
The name of a clip property
The value of the property for the given clip
DbExpression
The name of a column in the DB clip table
The value of the column for the clip row
An OperationExpression element has one attribute:
Attribute
Value(s)
Description
Comment
operator
Minus/Plus
The operator to be applied to the values of the operands. Details are given in the table below.
Both operators make sense for numerical arguments only, and have been implemented for integer arguments only.
An OperationExpression element has one sub-element: Operands. An Operands element has no attributes, but any number of expression sub-elements, meaning any number of ClipExpression, DbExpression, ConstantExpression, and OperationExpression sub-elements.
These sub-elements are the operands / sub-expressions of the OperationExpression.
Some further details on each operator:
Operator
Expression value
Minus
If there is one operand, the negation of the value of that operand. If there are two (or more) operands, the difference between the values of the first operand (minuend) and the second operand (subtrahend).
Plus
For any number of operands, the sum of the values of the operands. (As a special case, the ‘sum’ of no operands is zero. However, the Operands sub-element itself must be present. Anyway, a
<ConstantExpression value=0 />
would be more convenient.)
