Viz Mosart Template Database
The Viz Mosart Template Database (TDB) is used to share template information among the following clients:
Between galleries using Mosart automation. I.e. templates to be shared between multiple Mosart servers/galleries.
Between Mosart main and backup servers in a redundancy setup.
To NCS clients using Mosart ActiveX
To NCS clients using custom ActiveX
The template database is stored in a MySQL relational database or a valid MySQL equivalent such as MariaDb. The database may be installed seperately for the Mosart servers or as a part (schema) of an in-house or cloud database. The only main requirement to the database is that it is MySQL compliant. The template database may also be virtualized.
Mosart Template Definition
A Mosart template as stored in the template database has the following properties:
Property |
Description |
Gallery |
The Mosart gallery for which this template is implemented. |
Template set |
The Mosart template set which the template belongs to. A template set is either shared or local. See definition below. |
Template type |
The Mosart template type. I.e. like CAMERA, CLIP, DVE, … |
Template variant |
The Mosart template variant. I.e. like which camera (CAMERA+3) |
Template description |
Common attributes for the template which is shared among all galleries. The template description also contains a list of input fields normally known as newsroomtags. |
Template implementation |
Gallery specific information which is used to control systems using Mosart automation. This is the main part of the template and has to be implemented in every gallery. |
