AV Automation Devices Router
images/download/attachments/50598624/configuration_avauto-router.png
  • Use Router: Check to enable router control and select protocol from the list.
  • Router type: GVG G-SMS7000, SW-P-08 TCP/IP, SW-P-08 SERIAL, VENUS, VIKINX SERIAL or VIKINX TCP/IP.
  • Port: Serial port (GVG G-SMS7000, Venus, SW-P-08 serial, and Vikinx serial).
  • Bit rate: Selectable serial bit rate (GVG G-SMS7000).
  • Parity: Parity bit, default None (GVG G-SMS7000).
  • Main Host: Hostname or IP address of the main router (SW-P-08 TCP/IP and Vikinx TCP/IP).
  • Main Port: IP port of the main router (SW-P-08 TCP/IP and Vikinx TCP/IP).
  • Backup Host: Hostname or IP address of the backup router (SW-P-08 TCP/IP).
  • Backup Port: IP port of the backup router (SW-P-08 TCP/IP).
  • Additional parameters: For future use.
