Viz Ticker User Guide
Creating a Flipping Carousel Template Scene in Viz Artist
This section describes how to create a flipping carousel template scene in Viz Artist.
Tip: A copy of the flipping carousel template scene has already been created and can be imported by following the steps in To Import Viz Artist 3 Example Scenes.
When finished with the steps in this section, this template scene is used by the flipping carousel background scene. The Toggle plug-in in the background scene makes it possible to add text message templates to the carousel.
To Get Started
images/download/attachments/50594873/creating_scenename2.png
  • Create a new scene named tutorial-flipping-template.
  • Open the new scene.
To Add a Group
  • Add a new Group to the scene tree.
  • Rename it to object.
    Note: All flipping carousel template scenes must have a root container named object.
To Add the ControlObject Plug-in
images/download/attachments/50594873/creating_control_object_icon.png
  • Drag the ControlObject plug-in to the object container. Placing the control plug-in on the root container optimizes the process, as the whole template scene tree is copied when a new template is added, and the root container is the first one to be scanned.
    images/download/attachments/50594873/creating_controlobjecteditor.png
  • In the ControlObject Editor, enable Transition Logic.
  • Set the Layer identifier to Tutorial. The layer identifier refers to the layer director in the flipping carousel background scene.
    Tip:
    The layer identifier should consist of alphanumeric characters only. For more details, see Global Conventions.
  • Set the State identifier to Headlines. The state identifier refers to the in state stop point.
    Tip:
    The state identifier should consist of alphanumeric characters only. For more details, see Global Conventions.
  • Set the Background scene to tutorial-flipping-back.
  • Set the Description to simple text message. The description is used when selecting templates in Ticker Wizard and Viz Ticker Client.
To Add a Font
  • Drag a font to the scene tree, for example Arial-Bold, and place it as a subcontainer of object in the scene tree.
  • Rename the new container to text.
  • Open the text container’s Transformation Editor and set the Scaling to X,Y,Z= 0.2.
    images/download/attachments/50594873/creating_scaling2.png
    With this size, the text fits the background.
To Add a Material
Add a material, for example orange (R= 255, G= 102, B= 0), to the text container.
If no color is added, the font inherits the color of the container holding the Toggle plug-in in the background scene.
To Add the ControlText Plug-in
  • Drag the ControlText plug-in to the text container.
    images/download/attachments/50594873/creating_controltexteditor2.png
  • In the ControlText Editor, make sure that the Expose kerning option is disabled.
  • Disable Use formatted text.
  • Type Hi there! in the Input value text box. The scene tree should now have the following appearance:
images/download/attachments/50594873/creating_scenetree3.png
To Fine Tune the Position of the Template
  • Open the object container’s Transformation Editor and set the Axis Center to Y= C.
    images/download/attachments/50594873/creating_center.png
    When changing the axis center, the position changes too.
  • Reset the Position to Y= 0. These changes put the center of the template scene in the center of the Toggle plug-in placeholder container.
To Save the Scene
The template scene is now finished. Click the Save button.
