Viz Ticker User Guide
Installing Ticker Feed
Note: If Ticker Feed is already installed on the machine, you must first remove the old program version before installing the new one, see To uninstall Ticker Feed, see below.
  1. Run TickerFeed-<Product Version>.msi.
  2. Follow the on-screen instructions. Ticker Feed is now installed on the machine at the defined location.
  1. Select Start > Control Panel > Programs > Uninstall a program. Ticker Feed is no longer available on the machine.
Note: The software settings are not deleted with the software.
