Viz Ticker User Guide
Keyboard Shortcuts
The following keyboard shortcuts can be used to operate Viz Ticker:
Viz Ticker Client and Ticker Wizard
Function
Key + Mouse Combination
Select the next tab in the Main Menu
CTRL + TAB
Viz Ticker Client’s Pool Frame
Function
Jump to the Pool Search text box
CTRL + F
Copy currently selected messages
CTRL + C
Cut currently selected messages
CTRL + X
Delete currently selected messages
DELETE
Open a new message in Elements Editor based on the default template
CTRL + N
Open the Select Template dialog box, where any available message template can be selected
CTRL + T
Paste messages
CTRL + V
Select all messages
CTRL + A
Viz Ticker Client’s Carousel Frame
Function
Activate the Find text box in the Carousel Search
CTRL + F
Activate currently selected messages
INSERT
Deactivate currently selected messages
CTRL + INSERT
DELETE
CTRL + C
CTRL + X
Paste messages
CTRL + V
Select all messages
CTRL + A
Viz Ticker Client’s Elements Editor
Function
Save the current element
CTRL + S
