Viz Ticker User Guide
Quick Start Guide
This section lists the steps required to set up and use a basic Viz Ticker carousel. Each of the steps is described in more detail in the following sections of this User Guide.
Prepare all Systems
  • Start Viz Artist and set On Air.
  • Make sure that the Media Sequencer is running.
  • Start Ticker Wizard and delete any existing carousels or output channels. These must be deleted before setting up a new Ticker System, see Ticker Carousels Panel and Output Channels Panel.
  • Make sure that Ticker Service is running (only required for scrolling carousels).
Set Up a Carousel in Ticker Wizard
  • Connect Ticker Wizard to Viz Engine (Viz Engine Connection Frame).
  • Click Select Scene to select the carousel scene (Main Panel).
  • Click Create Scrolling/Flipping Carousel and select the carousel and templates you require (Wizards).
Use a Carousel in Viz Ticker Client
Activate the System
  • In Viz Ticker Client, select the CONTROL tab (Control Panel). This is only visible if the Viz Ticker Client Startup Parameters include -control on.
  • Set Ticker System Main to On.
  • Set Program Main to On.
  • Take the carousel on air by setting <CarouselName> Main to On. This button is available in the <CarouselName> tab and the CONTROL tab. Your ticker carousel should now be displayed in the rendering window.
