Viz Trio User Guide
Version 3.2 | Published June 29, 2021 ©
Adding Key Functions to the Container
  1. Add a key function to the background container.
  2. Click the key icon to open the key editor.
    • For Viz Artist 3.x: Click the Built Ins button, and select Function Container from the drop-list. The Alpha function is in the Global folder.
    • For Viz Artist 2.x: Click the Function button.
      images/download/attachments/68861410/design_basic_scene_lowerthird_key-editor.png
  3. The key for the background must have the Alpha as key only setting enabled; this prevents a "dirty" key if the background has some level of transparency.
  4. Set Render mode to Blend.
  5. Add a key function to the front_objects container. The Alpha as key only setting must be disabled, and Render mode must be set to Add, to prevent foreground objects from creating a hole in the background object's key signal.
