Viz Trio User Guide
Version 3.2 | Published June 29, 2021 ©
Adding a Background
images/download/attachments/68860983/design_primitives_rectangle.png
  1. Add a rectangle from the Built Ins object pool and drop it as a sub-container of the object container. Rename it Background.
    • For Viz Artist 3.x: Click the Built Ins button, and select Primitives from the drop-list. The object can be found in the Default folder.
    • For Viz Artist 2.x: Open the Object pool and click on the button labeled Built in.
      images/download/attachments/68860983/design_basic_scene_lowerthird_background_r.png
  2. Open the rectangle’s editor and the background container’s transformation editor to scale and then position the object so that it covers the lower third part of the screen.
    • Rectangle editor: Width 800 and Height 125.
    • Transformation editor: Position Y -160.
  3. Since this element is a background element it should be a little bit behind the other objects on the Z-axis.
    • Transformation editor: Position Z -100.
      images/download/attachments/68860983/design_do_adding_material_viz3.png
  4. Add a material (see To add materials) object to give the rectangle a color.
    • For Viz Artist 3.x: Click the Server button and select Materials on its drop-down menu (CTRL + 3 or the M tab).
    • For Viz Artist 2.x: Click the Material button to open the material database, and select a color.
  5. Drag the desired material from the material pool and drop it onto the Background container.
