Viz Trio User Guide
Version 3.2 | Published June 29, 2021 ©
Hardware Configuration
Two standard Viz Trio setups are detailed below.
Conventional Configuration
Traditionally, each Viz Trio system has required two standard desktop PCs to operate: one for the Viz Trio client and one for its companion renderer Viz Engine.
Viz Trio OneBox Configuration
You can also run a complete Viz Trio system, including the Viz Engine, on a single standard PC (desktop or rack mountable) with all the features of a conventional Viz Trio setup. Two powerful graphics cards ensure the same graphics quality and rendering speed. Both the VGA preview and final program signals (playout) can be viewed on the same machine.
Tip: The single PC setup is suitable when you have limited space, such as for OB vans, remote broadcasts, and small studios.
