Viz Trio User Guide
Version 3.2 | Published June 29, 2021 ©
Using Built-in Transition Effects
Built-in transition effects provide easy access to basic effects like cut and fade.
Configuring Built-in Transition Effects
  • For videos and stills: select the Use Transitions checkbox in Configuration settings. Go to File > Configuration > Output > Add Video. For more information, see Working With the Profile Configuration.
  • For graphic elements: the Viz output mode in Configuration settings must be changed from "Standard" to "Scene Transitions". This menu option can be set in File > Configuration > Output > Add Viz... “Mode”-option.
  • For transitions between stills and videos: the profile needs to define a channel for both video and graphic elements (Viz and Video output) or ensure that stills and video elements are played out on the same Viz Engine; transitions between video and graphic elements will otherwise not be possible.
Note: If one dual channel machine is being used for both program and external preview, the machine may not have enough capacity to show transitions on both channels. Should this occur, use a simpler preview scene for stills that does not support transitions. To enable this preview, the override concept PREVIEW must be specified for the external preview channel.
To view the effects column, right-click the playlist column and select Effect in the menu to make the column visible. Transition effects can be chosen individually per element or as a default for the playlist. Select default for a playlist from the default effect dialog by clicking the Fx.. button.
Info: Default values are shown in the effect column with bracket values [...]. Individual effects are shown without brackets.
The effect column in a playlist shows different effect sets depending on the element type:
  • still images and video elements (currently Cut and Fade).
  • graphic elements (the scene transition effects).
In Trio version 3 and later, there are two additional macro commands for setting default effects for a show:
  • show:set_default_scene_effect and
  • show:set_default_video_effect
  • Show in the Macro Commands and Events section.
