Viz Trio User Guide
Version 3.2 | Published June 29, 2021 ©
Import and Export Settings
To view the Import/Export configuration settings, click Import/Export Settings in the Trio Configuration.
Import/Export Configuration Settings
images/download/attachments/37573020/configurationinterface_config_import-export-settings.png
This function is used to import and export the configuration settings from and to an XML-file. This allows customized settings to be applied to one or more Viz Trio clients without manually configuring the settings each time.
Export: Enables the export of Viz Trio settings and profile configurations to an XML file. The following settings cannot be exported:
Import: Enables the import of Viz Trio settings and profile configurations from an XML file. Note that such an operation will overwrite existing settings and profiles, and that Viz Trio must be restarted for the new configurations to take effect.
