Viz Arc User Guide
Version 1.8 | Published October 13, 2023 ©
Action Properties
All Actions in the project can be accessed and modified via scripting. Use the GetAction function to get a reference to the action:
  • BaseAction GetAction(string actionName)
Note: It's possible for a project to contain multiple actions that have the same name. If that is the case for your project, the first Action created with a name is returned. Make sure to use unique names when accessing actions through scripting.
Every Action type has these generic properties:
Action type
Description
string Name
The title of the action.
string Description
By default this is the type of action (for example, "Key", "Chroma", "Image" etc.). When assigned to a TransformationAction and visible on the SET view, this field is used as a tooltip when the mouse hovers over the element.
int ExecutionDelay
Expressed in milliseconds, minimum delay is 0 (default), maximum delay is 10000 (10 seconds).
Every Action type has these generic methods:
  • void Execute(): Executes the action.
  • void Preview(): Executes the action on the preview channel.
  • void QueryState(): Queries the current state of the action from the Editing Engine. For example, if the action is a transformation action, it retrieves the current transformation from the editing engine's scene tree and updates the UI accordingly.
The example below shows how to set the alpha value to 75% of an Alpha Action called AlphaText and execute the action from scripting:
Sample
var alphaAction = GetAction("AlphaText");
alphaAction.Alpha = 75.0;
alphaAction.Execute();
There are specific properties/functions for each action type:
Alpha
Properties:
  • double Alpha
Chroma
Properties:
  • ChromaPrecisionContent Precision
    • double hueAdjust
    • double saturationAdjust
    • int edgeBlur
    • double despillScale
    • double backingPlateR
    • double yellowGain
    • double cyanGain
    • int denoiseRadius
    • int denoiseSharpen
    • double opacityPoint
    • doube transparencyPoint
    • double bgEdgeGain
    • double bgSpillGain
    • double bgLWBlur
    • double colorEdgeGain
    • double colorSpillGain
    • double colorLightwrapR
    • double colorLightwrapG
    • double colorLightwrapB
    • bool addShadows
    • double innerShadows
    • double shadowsGain
    • bool addHighlights
    • double innerHighlights
    • double highlightsGain
    • double masterLiftR
    • double masterLiftG
    • double masterLiftB
    • double masterGammaR
    • double masterGammaG
    • double masterGammaB
    • double masterGainR
    • double masterGainG
    • double masterGainB
    • double masterSaturation
Sample
var action = GetAction("Chroma");
// sample for setting some color Precision Keyer settings
action.Precision.hueAdjust = -1140;
action.Precision.saturationAdjust = 2.0;
Command
Properties:
  • string Command
ControlObject
See Control Object Classes.
Director
Properties:
  • string DirectorType
    • Possible values: START, STOP, CONTINUE, CONTINUE_REVERSE, PLAY_FROM, PLAY_FROM_REVERSE, FROM_TO, GO_TO, PAUSE
Group
This action has no additional public properties.
Properties:
  • string Image
    • Value should be a Graphic Hub path that starts with "IMAGE*"
  • bool IsBuiltin
  • string Builtin
    • Possible values: LIVE1, LIVE2, CLIP1, etc.
  • double PosX
  • double PosY
  • double RotX
  • double RotY
  • double RotZ
  • double ScaX
  • double ScaY
The Image parameter can be assigned to a Graphic Hub path when the string starts with "IMAGE*"; when it starts with "http" it will be assumed to be a web link (or a Media Service link), otherwise it will be interpreted as a local file path, see the samples below:
Sample
var imageAction = GetAction("Image");
imageAction.Image = "IMAGE*/VizArc/arcLogo";
// or
imageAction.Image = "http://127.0.0.1:21099/serve/original/AR_03.jpg";
// or
imageAction.Image = "C:/Users/admin/Desktop/CAKE.jpg";
Light
Properties:
  • string LightType [read only]
    • Possible values: NONE, SPOTLIGHT, DIRECTIONAL, AREA, POINT
  • string LightColor
  • double LightIntensity
  • double DiffuseIntensity
  • double SpecularIntensity
  • double LightRadius
  • double OuterConeAngle
  • double InnerConeAngle
  • int LightLayer
  • double DirectionalSpread
  • double RadiosityMultiplier
Key
Properties:
  • bool KeyEnabled
  • bool CombineBackground
  • bool DepthInfoOnly
  • bool DrawKey
  • bool DrawRGB
Material
Properties:
  • string ColorHex [#RRGGBB]
  • string Diffuse [#RRGGBB]
  • string Emission [#RRGGBB]
  • string Specular [#RRGGBB]
  • string Ambient [#RRGGBB]
  • double Alpha [0…100]
  • double Shiniess [0…100]
  • bool UseSimpleColor
Functions:
  • SetColorRBG(int r, int g, int b)
MSE
Properties:
  • string Page
    • Possible values: TAKE, CONTINUE, TAKE_OUT
Multizone Chroma Key
Properties:
  • string ZoneName
  • double Height
  • double Altitude
  • double Luminance
  • double MinLuminance
  • double MinGrad
  • double MaxLuminance
  • double MaxGrad
  • double Blend
  • double U
  • double V
  • double UVDiameter
  • double UVGradient
  • bool IsFullscreen
  • bool PickLuma
  • bool PickChroma
  • bool PickInViz
NDI
Properties:
  • int Preset
    • Value must be between 0 and 99
  • float Velocity
    • Value must be between 0 and 1
Omo
Properties:
  • int ElementIndex
  • bool ShowUntil
PBR
Properties:
  • Modes
    • bool IsPreload
    • bool IsGHMode
  • GH Mode
    • string PhongMaterialAsset
      • Value should be a Graphic Hub path that starts with "MATERIAL_DEFINITION*"
  • Values Mode
    • Material Settings
      • string ColorTexture
      • |string ColorTint
      • bool ColorIsSRGB
      • string EmissiveTexture
      • string EmissiveColor
      • double EmissiveIntensity
      • string NormalTexture
      • string RoughnessTexture
      • double RoughnessFactor
      • string MetallicTexture
      • double MetallicFactor
      • string AmbientOcclusionTexture
      • string HeightTexture
      • double HeightDepth
      • string EnvironmentTexture
      • double EnvironmentRotation
    • Texture Settings
      • double TillingU
      • double TillingV
      • double UvAngle
      • double UvScaleU
      • double UvScaleV
      • double UvOffsetU
      • double UvOffsetV
Phong
Properties:
  • Modes
    • bool IsPreload
    • bool IsGHMode
  • GH Mode
    • string PbrMaterialAsset
  • Values Mode
    • Material Settings
      • |string ColorTint
      • bool ColorIsSRGB
      • string AmbientTexture
      • string AmbientColor
        • For example: "#FF00A0"
      • double AmbientIntensity
      • string DiffuseTexture
      • string DiffuseColor
      • string SpecularTexture
      • string SpecularColor
      • double Shininess
      • bool Lit
        • Whether the material should be lit
    • Texture Settings
      • double UvAngle
      • double UvScaleU
      • double UvScaleV
      • double UvOffsetU
      • double UvOffsetV
Scene Loader
Properties:
  • bool UseGUID
  • string FrontUUID
  • string MainUUID
  • string BackUUID
  • string GfxUUID
  • string SubSceneUUID
  • bool FrontClear
  • bool MainClear
  • bool BackClear
  • bool GfxClear
  • bool SubSceneClear
  • bool FrontResetStage
  • bool MainResetStage
  • bool BackResetStage
  • bool GfxResetStage
  • int GfxLayerNumber [0,…,17]
  • bool SubSceneResetStage
Script
Functions:
  • dynamic GetParameterValue(string name)
    • Returns the value of a Script UI element. The name is the name of the UI parameter as specified in the viz script by the RegisterParameter* function.
  • bool SetParameterValue(string name, dynamic value)
    • Sets the value for a UI parameter. The name is the name of the UI parameter as specified in the viz script by the RegisterParameter* function. Returns true on success.
Example
// get the script action with the name "scriptA"
let action = GetAction("scriptA")
// set some parameter values
action.SetParameterValue("aDouble", 3.3)
action.SetParameterValue("aInteger", 2)
action.SetParameterValue("aString", "another string")
action.SetParameterValue("aMultiString", "another\\nmultistring")
action.SetParameterValue("aBool", false)
action.SetParameterValue("aImage", "c:/tmp/test.jpg")
// read the parameter values
Console.WriteLine("aDouble value is " + action.GetParameterValue("aDouble"))
Shared Memory
Functions:
  • String[] GetKeys()
  • String[] GetValues()
  • Void AddKeyValue (string key, string value)
  • Void InsertKeyValue (int index, string key, string value)
  • Bool Remove (string key)
  • Void RemoveAt (int index)
Telemetrics
Properties:
  • int Program
  • int Scene
Text
Properties:
  • string Text
Tracking Hub Command
Properties:
  • string Command
Transformation
Properties:
  • double PosX
  • double PosY
  • double PosZ
  • bool PosEnabled
  • double RotX
  • double RotY
  • double RotZ
  • bool RotEnabled
  • double ScaX
  • double ScaY
  • double ScaZ
  • bool ScaEnabled
Utah Router
Properties:
  • int Source
  • int Desitnation
Unreal Animation
Properties:
  • string AnimationMode
    • Possible values: LOAD, CONTINUE, PAUSE
  • bool IsLooping
  • double PlayRate
  • double BlendTime
  • string SelectedAnimation
Unreal Blueprint
Unreal Dispatcher
Unreal Scene Loader
Unreal Sequencer
Properties:
    • Possible values: START, STOP, CONTINUE, START_REVERSE, CONTINUE_REVERSE, PLAY_FROM, PLAY_FROM_REVERSE, GO_TO, PAUSE
  • int LoopCount
  • double PlayRate
Unreal Text
Properties:
  • string Text
  • double ScaleX
  • double ScaleY
Vinten
Virtual Studio
Properties:
  • int SelectedSceneIndex
  • bool SendPosition
  • string SetName
  • double PosX
  • double PosY
  • double PosZ
  • double RotY
Visibility
Properties:
  • bool Visibility
  • string VisibilityMode
    • Possible values: ON, OFF, ONOFF, DUAL_MODE
Viz Camera
Properties:
  • int SelectedCamera
  • bool RemoteEnabled
  • bool IsRemote
  • bool AngleEnabled
  • double Angle
  • bool PosEnabled
  • double PosX
  • double PosY
  • double PosZ
  • bool DirEnabled
  • double Pan
  • double Tilt
  • double Twist
Viz Clip
Properties:
  • string ClipName
  • bool IsLoader
  • string ControlType
    • possible values: START, STOP, CONTINUE, PAUSE
  • string SelectedClipChannel
  • bool PlayOnLoad
  • bool HasLoop
  • bool ShouldQueue
Viz PBR Material
Properties:
  • bool IsPreLoad
  • bool IsGHMode
  • string ColorTint
  • bool ColorIsSRGB
  • double TillingU
  • double TillingV
  • double UvAngle
  • double UvScaleU
  • double UvScaleV
  • double UvOffsetU
  • double UvOffsetV
