Viz Arc User Guide
Version 1.8 | Published October 13, 2023 ©
Main Menu and Project Toolbar
The Main menu contains the following sections:
File
All Project creation and management related actions are found in this menu.
images/download/thumbnails/81477300/arc_mm_file.jpg
  • New (CTRL + N): Creates a new blank project.
  • Open (CTRL + O): Opens existing project.
  • Save (CTRL + S): Saves the current project.
  • Save As (CTRL + SHIFT + S): Saves project with a different name.
  • Import: Imports a Viz Arc archive (.arc file).
  • Export: Exports a Viz Arc archive (.arc file).
Note: The same operations are also available from the Project toolbar: images/download/thumbnails/81477300/arc_proj_tb.jpg
Projects
Projects can be located on the local file system or on Graphic Hub. When opening a project you can choose where to load it from, selecting from either the Graphic Hub tab and the Local tab.
images/download/attachments/81477300/image2021-3-2_23-54-25.png
When saving a project, you can choose whether to store it locally or on Graphic Hub using the respective radio button.
images/download/attachments/81477300/image2021-3-2_23-55-28.png
View
This menu lets you switch between the three main views when working in Builder mode.
images/download/thumbnails/81477300/arc_mm_view.jpg
  • Actions: Switches to the Actions view in the main window.
  • Set: Switches to the Set view in the main window.
  • Script: Switches to the Script view in the main window.
Viz
This menu contains actions relating to Viz systems.
images/download/thumbnails/81477300/arc_mm_viz.jpg
  • Launch Viz Engine: Launches Viz Engine.
  • Launch Viz Artist: Launches Viz Artist (if licensed).
  • Maximize Viz Artist: Switches to the Viz Artist window.
System
images/download/thumbnails/81477300/arc_mm_sys.jpg
  • Configuration: Opens the configuration section in a new window.
  • Help: Opens the present manual.
Note: The configuration panel can also be opened by clicking images/download/thumbnails/81477300/arc_conf_ico.jpg at the top right.
