Viz Arc User Guide
Version 1.8 | Published October 13, 2023 ©
Configuring Viz Engine
In order to see a preview in Viz Arc, the following three settings in Viz Config must be configured:
Note: Please verify that your system meets the version requirements.
In Viz Engine, go to the Viz Configuration tab and select:
1. Video Output SHMOutput: Set Shared Memory Output option to Active.
images/download/attachments/105108662/ahmoutenabled.png
2. Video Board: For non-Matrox configurations, you must configure the following:
  • Software I/O Mode: Make sure SHM Channels is selected.
  • Check Video Card: Must be set to: User Defined.
For Matrox systems, just check the Matrox check box.
images/download/attachments/105108662/videoboard.png
