Viz Arc User Guide
Version 1.8 | Published October 13, 2023 ©
Troubleshooting
This page covers the following topics:
Vizrt Issues
Unable to Load Scene
images/download/attachments/81476970/unabletoloadscene-3.jpg
Make sure that there is a channel associated to a scene, and that you are connected to a Vizrt profile.
images/download/attachments/81476970/unabletoloadscene-2.jpg
Check if Viz Engine is up and running.
Viz Arc cannot find the selected scene. Check that you are connected to the correct Graphic Hub.
Graphic Hub Not Connected
images/download/attachments/81476970/ghnotconnected.jpg
  • Check if Graphic Hub is up and running.
  • Check in the Config window that the Graphic Hub REST settings are correct (Host/IP and Port, Username and password).
  • Check that the machine on which Viz Arc is installed is connected to the machine containing Graphic Hub.
  • Follow the procedure in General Configuration to correctly configure Graphic Hub REST in Viz Arc.
Preview Not Connected
images/download/attachments/81476970/Previewnotconnected.jpg
  • Check if Viz Engine is up and running.
  • Check in the Config window that the Viz GH and MSE settings are correct (Host/IP and Port).
  • Check that the machine on which Viz Arc is installed is connected to a Viz Engine.
  • See the section Configuring Viz Engine.
Output Initialize Failed
images/download/attachments/81476970/outputinitilaize.jpg
  • Check that Viz Engine is configured in RGBA output format.
  • Ensure that there is a valid Viz IP Stream Output license.
  • Check that you are using Viz Engine 3.9 or higher.
Cannot Connect/Send to Viz Engine
images/download/attachments/81476970/cannotconnect1.jpg
Check that Viz Engine is up and running and set in On Air mode.
images/download/attachments/81476970/cannotconnect2.jpg
Check that Viz Engine is set in On Air mode.
Cannot Send Shared Memory Commands
If Viz Engine can’t receive SHM commands, it's possible that the UDP and TPC ports are not configured in Viz Config.
In Viz Engine, go to Config > Communication > Shared Memory.
images/download/attachments/81476970/cannotsend1.jpg
For more information, see Profiles.
Unreal Engine
Unreal Engine not Available
images/download/attachments/81476970/unrealunavailable.jpg
  • Check that Unreal Engine is up and in Play Mode.
  • Check in the Config window that the Unreal Engine settings are correct (Host/IP and Port).
  • Check that the Viz Arc machine is connected to the machine containing Unreal Engine.
  • Check that you have copied the arcCom plug-in folder to \Epic Games\UE_4.20\Engine\Plugins.
  • See Profiles for more information on configuring Unreal Engine in Viz Arc.
Cannot Connect/Send to Unreal Engine
images/download/thumbnails/81476970/sendtounreal1.jpg
Check that Unreal Engine is up and running and set in Play mode.
images/download/thumbnails/81476970/sendtounreal2.jpg
Check that Unreal Engine is set in Play mode.
Unable to Load Unreal Level
images/download/thumbnails/81476970/loadunreal1.jpg
Ensure that there is a channel associated to a Level, and that you are connected to an Unreal Engine profile.
images/download/thumbnails/81476970/loadunreal2.jpg
Check that Unreal Engine is running and in Play mode.
images/download/thumbnails/81476970/unabletoloadscene-3.jpg
Viz Arc cannot find the selected Level. Check that you are loading a Level that exists in the selected project.
Support
