Viz Arc User Guide
Version 1.8 | Published October 13, 2023 ©
Launching Viz Arc
Once you've installed Viz Arc, you're ready to start using it! If you don’t have a license yet, the following (or similar) message appears:
images/download/attachments/120718754/nolicencefound.png
Command Line Arguments
The following command line switches can be used:
Switch
-o, --onair
Start Viz Arc in On Air Mode.
--project name
The name of the project to be loaded at startup.
Use prefix "local:" or "file:" to explicitly specify a project form the local file system or
use the prefix "gh:" or "graphichub:" to specify a project stored on Graphic Hub.
--projectgh name
The name of the project on Graphic Hub to be loaded at startup.
--programdatapath path
Specify the Viz Arc ProgramData Folder (for example, C:\ProgramData\vizrt\VizArc).
--noproject
Force startup without any project loaded (default is to open the last opened project).
-t, --tracking
Start Viz Arc in Tracking Mode.
-a, --arena
Start Viz Arc in Arena Mode.
--help
Display help when started from a console.
Examples
VizArc.exe --project gh:VirtualSetA: Starts Viz Arc loading the project VirtualSetA from Graphic Hub.
VizArc.exe --project local:ObjectTracker -t: Starts Viz Arc loading the project ObjectTracker form the local file system and it starts up with the Object Tracker user interface already opened.
