Viz Arc User Guide
Version 1.8 | Published October 13, 2023 ©
Control Object Classes
After having accessed the action holding the list of ControlObjects thought the GetAction method, the single ControlObjects can be retreived using the global method
  • BaseControlObject GetControlObject( BaseAction action, string ControlObjectID )
Most Control Object types have the following generic properties:
  • Text (String)
    • This property adapts to all objects (execute string)
    • IntControl.Text = "5"
    • ImageControl.Text = "IMAGE*FolderA/SubfolderB/ImageName"
  • ID (String)
    • Returns ObjectID
  • Description
    • Returns the object description
Each Control Object type has specific properties:
Control Container
Properties:
  • Visibility
  • Position
    • posX (double)
    • posY (double)
    • posZ(double)
  • Rotation
    • rotX (double)
    • rotY (double)
    • rotZ (double)
  • Scaling
    • scaX (double)
    • scaY (double)
    • scaZ (double)
This type doesn’t have the Text property.
Control Image
Properties:
  • Path (string)
  • Position
    • posX (double)
    • posY (double)
  • Scaling
    • scaX (double)
    • scaY (double)
Control Material
Properties:
  • Path (string)
Control Omo
Properties:
  • Value (integer)
Control Text
Properties:
  • Value (string)
Control List
Example:
sub OnInit()
'declare variables
dim objAction, table, cell
dim output1, output2, output3
'get table obj action
objAction = arc.GetAction("object")
table = arc.GetControlObject (objAction, "controlObj_ID")
Console.WriteLine("Table name: " & table.Text)
'set values in single cells inside the table
table(0,0).value = false
table(0,1).value = 5
table(2,5).x = 12
table(3,6).value = "IMAGE*/Default/GER"
'assign values to a variable and show in debug console
output1 = table(0,0).Text
output2 = table(0,1).Text
output3 = table(0,2).Text
Console.WriteLine("cell - " & output1 & " | " & output2 & " | " & output3)
end sub
Properties:
  • Accessor
    • table[int row, int col]
      returns a cell
    • nbcolumns (integer)
      number of columns
    • nbrows (integer)
      numbers of rows
Single Cells Properties
Cell
Type
Additional Information
Example
BaseCell
Text (string)
Sets or gets value as string.
Common to every cell type.
table(0,5).x= 12 (intCell)
table(0,5).text = "12" (intCell)
BoolCell
Value (boolean)
table(0,5).active= true
DoubleCell
Value (double)
table(0,5).x= 12.8
DupletCell
X (double)
Y (double)
table(0,5).text = "0.55 0.2"
GeomCell
Value (string)
table(0,5).value = "GEOM*/folder/geometry"
ImageCell
Value (string)
table(0,5).value = "IMAGE*/folder/image"
IntCell
Value (integer)
MaterialCell
Value (string)
table(0,5).value = "MATERIAL*/folder/material"
TextCell
Value (string)
TripletCell
X (double)
Y (double)
Z (double)
table(0,5).text = "0.55 0.23 1.23"
Control Integer
Properties:
  • Value (integer)
Control Double
Properties:
  • Value (double)
Control Boolean
Properties:
  • Value (boolean)
