Viz Arc User Guide
Version 1.8 | Published October 13, 2023 ©
WIBU-based Licensing System
This chapter describes management and usage of the licensing system based on CodeMeter from WIBU Systems available in Viz Arc 1.0 and later.
Important: Any change in the license configuration requires a restart of Viz Arc.
Important Pre-installation Information
The WIBU licensing system requires the installation of the CodeMeter Runtime Software (included in the Bundle installer):
6.80 and newer
When the license should be retrieved from a dedicated license server, it must be configured in the Vizrt Licensing Service (see Client Configuration section of the Vizrt Licensing Administrator Guide) or the CodeMeter WebAdmin.
Info: There is an auto discovery if no license server is configured in the server search list of CodeMeter.
Info: On network disconnect and reconnect, it may happen that a license is checked out twice. Should that occur, release the license manually on the CodeMeter service on the license server or restart the license server.
