Viz World Plug-ins Guide
Container Plug-ins
This chapter describes container plug-ins. The container plug-ins are found in five plug-in folders:
  • Maps: Contains standard plug-ins.
  • Maps-Adv: Contains advanced plug-ins.
  • Maps-Lab: Contains experimental plug-ins. Since these plug-ins are experimental and not supported, they are not documented here.
  • Maps-Man: Contains a set of Manager plug-ins used for batch creation of 3D Objects such as regions, borders, and so on.
  • Maps-Obs: Contains obsolete plug-ins, installed only for backward compatibility. These plug-ins should not be used when designing new scenes. Since these plug-ins are obsolete and not supported, they are not documented here.
  • Tools: Contains tool plug-ins.
See the following sections for more information:
