Viz World Plug-ins Guide
Shader Plug-ins
This chapter describes shader plug-ins. The shader plug-ins are found in two plug-in folders:
  • Default: Contains the Rebound plug-in.
  • Maps: Contains standard plug-ins.
  • Maps-Adv: Contains advanced plug-ins.
  • Maps-Lab: Contains experimental plug-ins. Since these plug-ins are experimental and not supported, they are not documented here.
  • Maps-Obs: Contains obsolete plug-ins, installed only for backward compatibility. These plug-ins should not be used when designing new scenes. Since these plug-ins are obsolete and not supported, they are not documented here.
  • Texture: Contains the FadeTexture plug-in.
See the following sections for more information:
