Viz World Plug-ins Guide
Shadow Agent
images/download/thumbnails/44386346/viz_icons_shadow_agent.png
The Shadow Agent plug-in is an agent for the Shadows parameters covered by the scene plug-in Label Manager.
Note: This plug-in is located in: Built Ins -> Geometry plug-ins -> Maps_Adv
Shadow Agent Properties
images/download/attachments/44386346/plugins_geometry_shadow_agent.png
  • Render With Camera: Defines for which camera shadows apply.
    • All: Renders shadows on all cameras (Compatible with previous versions).
    • Label: Renders shadows only for the defined off screen labels camera.
    • Map: Renders shadows only for the defined map camera.
    • Shadow: Renders shadows only for the defined shadows camera, as defined in the Label Manager plug-in (Shadows tab).
