Viz World Plug-ins Guide
Map Builder
images/download/thumbnails/44386384/viz_icons_maps_builder.png
The Map Builder plug-in builds a scene from a map template (*.mtpl) file, and saves the map scene changes to the map template file.
Note: This plug-in is located in: Built Ins -> Scene plug-ins -> Maps
Map Builder Properties
images/download/attachments/44386384/plugins_scene_maps_builder.png
  • Map Template Filename: Sets the name of the scene template file or click the browse (...) button to select a file.
  • Rebuild Scene: Updates the scene tree with changes from the Map Builder.
  • Launch Wizard: Runs the Map Builder application.
  • Clean Scene: Cleans the scene hierarchy.
  • Build Scene from Scratch: Cleans the scene tree and rebuilds the scene hierarchy using the defined map template file.
