Chroma Keyer
images/download/attachments/41798778/ico_chroma_key.png
This Shader clear regions in a video defined by a color. The color-space of this Shader is YUV, which is defined as following:
images/download/attachments/41798778/ia_keying3.png
The luminance (Y) component determines the brightness of the color, while the U and V components determine the color itself (the chroma). Luminance (Y) ranges from 0.0 (dark) to 1.0 (bright). U and V ranges from -0.5 to 0.5.
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Chroma Keyer Properties
images/download/attachments/41798778/psh_cke_1.png
  • Video: Sets the input video channel for keying. Be sure that for the set video channel the Keying Mode has been set to M-Zone (see Keying Mode).
  • Blend: Sets the alpha for the key signal.
  • Fit: Alters size to fit Screen or Object.
  • Invert: Flips the key signal.
  • Sampling Filter:
    • Nearest: Takes color information from one pixel.
    • 1D-Filter: Takes color information after applying a 1D-linear filter.
    • 2D-Filter: Takes color information after applying a 2D-linear filter.
  • Luminance: Sets the luminance.
Basic parameters for first method:
images/download/thumbnails/41798778/psh_cke_method1.png
  • HueAngle: Selects the color to key in YUV space.
  • OpeningAngle: Determines tolerance for the color in YUV space.
  • KeyGain: Determines gradient for borders to neighboring colors (1=soft, 10=sharp).
  • SatMin: Determines lower saturation limit for keyed colors.
  • SatMinGrad: Determines gradient for lower saturation limit (0=sharp, 1=soft).
  • SatMax: Determines upper saturation limit for keyed colors.
  • SatMaxGrad: Determines gradient for upper saturation limit (0=sharp, 1=soft).
Basic parameters for second method:
images/download/thumbnails/41798778/psh_cke_method2.png
  • U-Color: Determines U-value for color keying.
  • V-Color: Determines V-value for color keying.
  • UV-Diameter: Removes all colors between the reference UV and this diameter.
  • UVGradient: Determines gradient for fade out at diameter border (0=sharp, 1=soft).
Removing keying from Highlights and Shadows:
images/download/thumbnails/41798778/psh_cke_2.png
  • LumMin: Sets lower luminance limit for keyed colors.
  • LumMinGrad: Sets gradient for lower luminance limit (0=sharp, 1=soft).
  • LumMax: Sets upper luminance limit for keyed colors.
  • LumMaxGrad: Sets gradient for upper luminance limit (0=sharp, 1=soft).
Sampling reference point:
images/download/attachments/41798778/psh_cke_3.png
  • UVRangeCheck: Obtains information about the sampled color.
  • URangeMin: Defines the minimum UColor that should be accepted.
  • URangeMax: Defines the minimum UColor that should be accepted.
  • VRangeMin: Defines the minimum UColor that should be accepted.
  • VRangeMax: Defines the minimum UColor that should be accepted.
  • SampleTrustiness: Determines percentage of samples in the limited UV-Color space.
    images/download/thumbnails/41798778/psh_cke_4.png
  • Pos. X: Deternines X-coordinate for sampling.
  • Pos. Y: Deternines Y-coordinate for sampling.
    Note: The origin of the coordinate system is in the upper left corner.
  • Width: Sets number of pixels in x-direction.
  • Height: Sets number of pixels in y-direction.
  • Sample at Pos: Replaces XY-coordinates of the object center if Pos. X and Pos. Y are enabled. If disabled, the XY-coordinates are set by values in the interface.
  • Get Sample: Samples another time the reference point.
