Soft Mask
images/download/attachments/41798759/ico_softmask.png
The Soft Mask plug-in applies a soft mask to an object (e.g. image or geometry).
images/download/attachments/41798759/psh_softmask_sx.png
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Soft Mask Properties
images/download/attachments/41798759/psh_softmask_e.png
  • Progress: Moves the mask perpendicular to the mask direction. Default is 0.0 and is based on the configured center position.
  • Rotation: Rotates the mask around the center.
  • Keep Aspect:
  • Center X and Y: Defines the X and Y position of the center of the mask.
  • Gradient Width: Sets the size of the gradient.
  • Invert: Inverts the mask.
  • Mirror Gradient: Mirrors the mask on both axis.
  • Blank: Offsets the area that should not be affected by the mask.
  • Tracking: Allows the progress to be controlled by a tracked Container to build the progress animation easier. Drag a Container to the drop zone.
