Text Auto Scale
images/download/attachments/41798690/ico_textas.png
Text Auto Scale automatically scales text within a Text Box area as defined in the Text Editor.
Text Auto Scale Properties
images/download/attachments/41798690/pc_tas_e.png
  • Enabled: The plug-in is enabled by default when added to a container. Click the button to disable.
  • Default x-scale: Sets the default scale value for the X-axis.
  • Default y-scale: Sets the default scale value for the Y-axis.
Tip: When using the Text Auto Scale plug-in, Text Box scaling should be set to Off to avoid conflict in scaling operations.
