Image Mask
images/download/thumbnails/41798769/ico_imagemask.png
The Image Mask plug-in applies a mask to an image using other images (e.g. an alpha image).
images/download/attachments/41798769/psh_imagemask_sx.png
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Image Mask Properties
images/download/attachments/41798769/psh_imagemask_e.png
  • Image: Placeholder for image.
  • Blend: Blends the image with the object.
  • Position X, Y %: Sets the position of the mask in percentage for the screen or object.
  • Scale X, Y %: Sets the size of the mask in percentage for the screen or object.
  • Fit: Selects the size of the image mask to the screen or the object:
    • Screen: Sizes the image mask to the screen. If the object is moved, it moves while the image mask stays fixed.
    • Object: Sizes the image mask to the object. If the object is moved, the image mask moves with it.
  • Wrap:
    • Repeat: Applies the image mask multiple times on the screen or object.
    • Clamp: Applies the image mask once on the screen or object.
  • Mask Aspect: Sets the aspect of the image mask to the screen or the object.
  • Invert: Inverts the image.
  • Alpha only: Enables the alpha channel for the image (for example, an RGBA image).
  • Soft Mask: Applies a soft mask (available when Fit is set to Screen).
