Connector
images/download/attachments/41797420/viz_icons_connector.png
This plug-in is useful to connect two objects with a line in a required color and width.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
Connector Properties
images/download/attachments/41797420/plugins_geometries_connector_editor.png
  • Use LOD: Enables/disables dynamic level of detail.
  • Container 1 and 2: Placeholder for container 1 and 2. Drag the container onto the drop zone. Click R to remove the container.
  • Connection Point 1 and 2 By X, Y and Z Axis: Sets the X, Y and Z-value of container 1 and 2 where the line should start. Can be set to Min, Center, Max, CenterBB or Origin.
  • Line Width: Sets the width of the connecting line.
  • Drawing Mode: Available options are Line and Mesh.
  • Line Color: Defines the color of the line.
  • Border Thickness: Applies a border with the thickness determined by the value.
  • Border Color: Defines a border color.
To Connect Two Objects
images/download/attachments/41797420/plugins_geometries_bipconnector_example.png
  1. Create a new group and add the Connector plug-in to it.
  2. Create two new group containers and add a geometry object (e.g. Cylinder and Cone) to each group.
  3. Open each container’s transformation editor and move the objects a part.
  4. Add a material and/or an image to the geometry objects.
  5. Open the connector plug-in editor and drag and drop the two containers to the Container 1 and Container 2 placeholders, respectively.
  6. Adjust the color line.
  7. Open the Connector plug-in editor and play with the settings.
  8. Add more objects to Container 2 and animate it.
