Mark Text
images/download/attachments/41798388/viz_icons_marktext.png
The Mark Text plug-in allows you to highlight or underline words in a text string.
Mark Text Properties
images/download/attachments/41798388/plugins_container_marktext_editor.png
  • Text to Mark: Sets the text that should be highlighted. The text is case sensitive.
  • Multiple marks: Highlights all matched text.
  • Use regular expression: Allows regex to be used for more sophisticated highlighting.
    images/download/attachments/41798388/plugins_container_marktext_editor_regex.png
    • Only matched group: Highlights only on capture-groups (value) , other matched texts outside capture-groups or inside non-capture-groups (?:value) are not.
    • Case insensitive: Matches both upper and lower case.
    • Grammar: Selects one of the following supported grammars:
      • ECMA
      • Basic
      • Extended
      • Awk
      • Grep
      • Egrep
  • Mark: Selects which text should be highlighted. Available options are foreground (Front), background (Shadow), Both and None. Background highlights the text’s shadow.
  • Size: Sets the thickness of the highlight.
  • Position: Sets the y-position of the highlight in relation to the text.
  • Depth: Sets the z-position of the highlight in relation to the text. This allows the highlight to move behind the text.
  • Foreground Color: Sets the color and alpha value of the highlight.
To Mark Text
  1. Add a group container to the scene tree and name it Text.
  2. Add a font to the Text container.
  3. Open the font editor and enter a text string.
  4. Add the Mark Text plug-in to the Text container.
  5. Open the Mark Text Editor and enter a word from your text string or regex if enabled.
images/download/attachments/41798388/plugins_container_marktext_scene_example.png
From this example:
  • Text to mark: (?:the|a) (\w+)
  • Use regular expression: on
  • Only matched group: on
  • Case insensitive: on
  • Grammar: ECMA
Note: Do not change the font type between texture and geometry as this does not affect the whole string when using the Mark Text plug-in.
Note: Overlapping marks could occur with narrow character spacing or kerning. This would be visible in case of transparent marks.
